Has your car been in an accident? I suppose plastic could get old, but i think the window regulator is metal, isnt it? I didnt think that could crack.
- CIK7
- Has thanked: 327 times
- Been thanked: 87 times
- Has thanked: 304 times
- Been thanked: 517 times
I've seen things like window regulators crack, often it's with aftermarket parts that use cheaper metal. They actually deal with a lot of flex, and that can fatigue the metal over time and cause it to crack and bend.
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 130 times
Finally changed the oil in the S70.... Mahle filter and Rotella T6 5w40.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
Hi,
How do you get under the car?
454cid
I was in my uncles heated garage, so I used a floor jack, and a small jack stand on the passenger side.... at the risk of some old oil running to the driver's side in the pan. I put the floor jack behind the wheel, where the subframe bolts to the body, and the jack stand under the subframe.
If I had been home in the driveway (too cold and wet) I would have used my plastic ramps, and driven the car up.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
If you use a pump such as the one June recommended or a manual extractor you won't need to remove the plug. Have been doing this since mid 2019. The amount of oil residue is negligible (have pulled plugs to confirm) considering there was a pan full of dirty oil and it's going to be that dirty again in a couple thousand miles.
As for the filter, lift the car slightly with a floor or OE jack and a stand under the front sub frame. You don't need to fully go under. Some card board and a plastic bag for the filter or filter housing. After loosing the filter put the plastic bag over the filter and then the rubber band should slip over the top of the bag / filter when turning to remove. I didn't think of the rubber band till after taking the photo below. Should be able to catch a large amount of oil besides not getting it all over your glove or card board.
June's link.
viewtopic.php?p=620536#p620536
- MrAl
Hi,
Have you seen how the oil filter is buried in the 1998 v70? I can find a pic.
I'd be lucky to get a bag around it.
I dont like going under vehicles anymore though this car is way too heavy.
- v70-1998-oil-filter_20230307.jpg (38.48 KiB) Viewed 1085 times
- v70-OilFilter_04-07-2015b.jpg (48.91 KiB) Viewed 1082 times
You’d be terrified by an XC90 if you think these are heavy!
Seriously, I even get nervous jacking that thing up. It’s very awkward to lift.
- MoVolvos
Once you loosen it, just before it starts to drip slip a bag over it and move the rubber band all the way to the top of the thin grocery bag before spinning. The S70 changed to the cartridge, not sure when in the later models and that does not spin freely as the gasket is in contact with the threads all the way down.
- Has thanked: 1505 times
- Been thanked: 3818 times
That baggie and rubber band trick is brilliant.
Duly appropriated.
Duly appropriated.
