Hi!
I received an 017D fault code in SRS module. Has anyone encountered this error? I didn't find any relevant solution.
And I also got a 0101 fault code. And it's not possible to clear them.
Can it cause by a bad SRS module? (However, I did not receive 0001 fault code.)
It's also interesting because the seatbelt reminder is working. When I fasten my belt the buzzing stops (in the driver's seat).
I cleaned the connectors (greens, both under the driver and passenger side) and sprayed them with some contact spray. However, I still can't delete the faults.
My ICarsoft diag is detected when I fasten my seatbelt in the passenger seat. However, the buzzer is not working (only works in the driver's seat). In my opinion, the passenger seat occupant weight sensor is bad. These cars were assembled with OWS on the passenger side?
SRS fault code
