454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 131 times
Took the 850 out for a wash and an Italian tune-up (as best I could with traffic). It hasn't been out of the driveway (yard really) since last November. I had forgotten the rattle I can hear sometimes, and what I think is a bit of wheel bearing hum.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 1505 times
- Been thanked: 3818 times
She is going to get the cylinder head job she deserves for 30k trouble free miles , shuttling me during Covid, daughters first job, one rescue mission to central nY, and a rescue mission from foggys place in DE.
- Has thanked: 1850 times
- Been thanked: 1712 times
Shagg will then be like new! Good for another 20 years!
- P80GLT
- Has thanked: 154 times
- Been thanked: 176 times
Took the 850 for a drive to warm up the oil
Once home I removed the sump splash guard, there wasn't a single drop of oil or water on it, it was as clean as the day I fitted it 3 years ago
Removed the sump plug and left it to drain overnight
Last oil change was 5th April 2020 at 59,061 miles
Now 3 years on I'm at at 61,962 miles, a total of 2901 miles, that's plenty...
Not forgetting the new sump plug washer
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
Hi,
You have your own car lift?
He really though he would sneak that garage picture in without getting the grilling…
- P80GLT
@ MrAl, Yes I have my own lift, I built the garage in 2008 nd had planning permission for a pit, but when I excavated the hole it filled with water due to the height of the water table, so I filled it in and installed a lift...
Old filter removed this morning and left to drain again for another hour, new filter primed and fitted, sump plug refitted with new washer, 5.3 litres of Castrol 10W-40 A3/B4 poured into the engine, checked for leaks and sump cover refitted, service light reset and we're ready for another summer, bring on the sunshine
- Sveedy
- Has thanked: 417 times
- Been thanked: 457 times
Beautiful setup you have there ! I was going to go the pit route ( built one once before ), but 2 post lifts are much more affordable than they used to be, so that will end up being cheaper than the pit in the long run. 4 post is nice !
1999 V70 GLT
1999 V70 GLT
Pits are what I grew up working with. But here in Calgary where we have been for the last 20+ years, apparently people are too stupid to be allowed to own a garage work pit as they are likely to run the engines and gas themselves! Where we currently live a pit would not be an option either as we discovered a spring runs under this area so high water table and 3 sump pumps.
I have previously built 2 garages with the plan to install a hoist, but we moved before that could happen. So after 50+ years of planning and now retired the 3rd garage was built and this time a used hoist went in!
The original garage is under the rear of the house and not even 8 feet high. Door is just over 6ft!! So we built the new garage in front of the old garage and you can walk all the way into the house from the new garage. Old garage is to store the R over the winter and workshop for smaller bench type projects all year.
Very fortunate and forgiving wife!
- P80GLT
Huge debates of the for and against 2 post and 4 post lifts. Only reason I went 4 post was I had a 1947 car at the time and I really didn't want to raise it on a 2 post lift
