Under boosting 1997 850 t-5 after replacing parts
Okay I bought the car year and a half ago, great car. But soon it has developed a under boosting problem I replaced the tcv with the ipd tcv as well as silicone hosing, and also the cbv. Im utterly lost the car has close to 200k miles, great condition no check engine light. I may be thinking its a clogged cat but I haven't checked. I've hit a dead end. If any of you can help please and thank you!
- Has thanked: 2210 times
When you assembled the IPD TCV, did you screw the 'front' leg all the way home? If you did you may be getting little or no boost. Stupid design. If you screw the front leg in more than 3-4 turns it crushes the little filter and jams the valve.
When I installed the IPD tcv, I installed it first then I sent it to a shop to look at the turbo since I wasn't getting as much boost, and they might have screwed it all the way. Any way that I can revert it? Thank youscot850 wrote: 10 Apr 2023, 23:37 When you assembled the IPD TCV, did you screw the 'front' leg all the way home? If you did you may be getting little or no boost. Stupid design. If you screw the front leg in more than 3-4 turns it crushes the little filter and jams the valve.
Nope! Once the filter is crushed, it is done. I got a free replacement from IPD after complaining about their info not stating the issue. I have also told them a number of times to fix their instructions.
You could try removing the filter and see if at least it makes a difference. I would check if the arm is turned all the way in first. If it is not then you may have dodged a bullet. If it has been then removing the filter may be the only way to see if it will move. You and check if the little valve move. The standard TCU operated up to around 12-14psi, so if you have the original or can gt one from a junk car it may be worth trying to eliminate it as an issue.
I have several of the 98- TCV's from junkyards, but I seem to recall the 850 turbo ones were different shaped. Not sure if that makes any difference?
So you are at least getting boost, but not where it should be in terms of revs? At least a step in the right direction. Sveedy knows more about these things than I will ever know so I would follow his suggesiton.
When I had a problem with the IPD turbo TCV, I contacted them and complained about the issue. In your case add you gave it to pros to install and as there was nothing to say different, they cranked that front leg in jamming the valve. Also mention you only found out about the problem doing that obviously after the event.
Which TCV did you use? The rectangular shaped one from a V/S70 or the round one from an 850 like this link?:
https://www.ebay.com/itm/181437504669?_ul=CL
- 1161 Views
Last post by nthnnxn
- 11 Replies
- 2961 Views
- 1667 Views
Last post by jonesg
- 2212 Views
Last post by Reys
- 1312 Views
Last post by 800artfreed
