yanga001
Has thanked: 62 times
Been thanked: 115 times
Post by yanga001 »
Joined the P2 gang today, taking car for safety tomorrow.
2008 S60 2.5T Auto (Sold)
Has thanked: 2202 times
Been thanked: 1852 times
Great news you found a replacement Volvo!!
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
Today when in the glovebox I noticed a broken cord at the rear and after a bit of investigation I discovered it was for the soft open mechanism.
I stripped the glove box out and try as I might there was no way I was going to get a secure fixing for the cord with the brass ferrule so decided to restring the entire mechanism
It's not the easiest of items to dismantle, the bottom part of the plunger is tricky to separate and requires gentle persuasion.
It took me several attempts with the length of the cord before I found something close to what it should be. I settled for 195mm between the knot and top of the loop
All back together and ready to refit. Note the end grommit should be on in the opposite direction
Grommit is inserted from behind
Now working as it should
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
hughiescho
Year and Model: 2006 V70 2.5T
Has thanked: 15 times
Been thanked: 3 times
Post by hughiescho »
So cool PG80GLT!
yanga001
Post by yanga001 »
Fixed my front and rear bulb out errors. The front blinker has a wierd wire splice to connect the driver turn signal. Need to fix it up.
yanga001
Post by yanga001 »
Planning on pulling every fuse and relay in the car and cleaning it with sand paper before putting it back in. May dielectric grease some in contacts in the engine compartment we will see.
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
I’m doing some highly technical work today -
A new brake light bulb, spray some of the winter off, and take off the snow tires.
P80GLT
Post by P80GLT »
I decided my task today would be to fit my USB socket/voltage gauge into the space for the 12v socket of the CCM. I had previously fitted this to the XC90 and removed it before selling as it’s always handy to know the state of the battery and charging, plus USB is more convenient that a 12v socket.
I bought this from Amazon about 5 years ago and discovered the diameter was too large to fit into the hole when the 12v socket was removed.
I put it in my lathe and removed the threads plus a little more until it was a good tight fit.
Today was supposed to be an quick easy job that took way longer than it should as I decided whilst the CCM was out I may as well remove the cup holder and de-gunk whatever had been spilled in there causing it not to open.
2010 XC90 SE...SOLD
2005 V70 2.5T SE
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
We are moving to a new place. All my car tools are still in my old garage. Today I drove on a battery down there to replace a dead alternator. I had it rebuilt a few years back, but it started acting up a year ago and died completely a few weeks ago. Have no time to figure out what did I do wrong, decided to replace it with a brand new Bosch alternator. So I did it. While working on it, after 2 years of idle time (was driving big Toyotas mostly), I had a flash back of ole good times when I almost slept under broken Volvos. You know... Garage twilight, old leather and hot lubricants smells... And I got drunk. No need in printed instructions, VIDA, howtos, youtube - I did it zillion times. An old friend from past had called and we had a sentimental talk... Ah, ole good times...
BlackBart
Post by BlackBart »
Thanks Blizzaks! You were great!
