850 mods...??
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
black 850
850 mods...??
Post by black 850 »
i was wondering if wnyone knew what the best modifications where to do on a '96 850turbo?? to better my preformance. :twisted:
Thanks,
-kourosh
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2656 times
Been thanked: 1248 times
Post by matthew1 »
Without a doubt:
https://www.matthewsvolvosite.com/chips.php
I've got a strut brace; it helps the ride and cornering.
Also -> Amazon link
parksah07
Year and Model:
Post by parksah07 »
would a strut brace help a 98 v70, just basically for the ride/cornering? non-turbo
matthew1
Site Admin
Post by matthew1 »
Yes, because it's the same frame as 850 -- not the tightest ever designed, but ok for 1992/93 when it came out.
Also -> Amazon link
csbrianp
Year and Model:
Post by csbrianp »
Decide what area you want your car to perform better. If you want straight line performance than read the "how to tip" on increasing your boost. I increased mine 2 turns. Buy a good air filter, and ditch your muffler for a after market "turbo muffler" or "Flow Master". Those three items should make your car a 14 sec car.
If you want it to turn with the BMW M3 at the end of the long straight, add larger sway bars with good bushings, install a (good) set of lowering springs, and for that added touch 15mm wheel spacers in the rear.
Of course buy yourself a great set of brake pads to help slow it down.
I have all of the above except sway bars added to my car and the difference between now and stock is crazy. I run my car on the road course at Phoenix International Raceway, and the in stock form the tires would scream just looking at the coming corner. Now with the car being lowered the tireSsare silent and my track times went from 1:27 down to 1:22. I just added wheel spacers and hopefully will get into the 1:20s.
Brian
Mr. Norm
Post by Mr. Norm »
IMHO, the biggest bang fer the buck handling improvement is IPD sway bars. Much bigger than the strut brace. The brace is nice, but do the sway bars 1st.
parksah07
Year and Model:
Post by parksah07 »
strut bar helps cornering and off the line torquing?
but what does the sway bar do?
Mr. Norm
Post by Mr. Norm »
Kills body roll and understeer.
parksah07
Year and Model:
Post by parksah07 »
would you then need 2 sway bars?
are they hard to install? i know the strut bar isnt really hard at all
csbrianp
Year and Model:
Post by csbrianp »
Personally I would only add a bigger front sway bar. Volvo 850's have an over-steer handling trait, which means when pressed in a turn the car will loop. The bigger bar will change the handling Characteristics of the car altogether. The first thing you'll notice is that the car turns immediately no lean, just turn. It changed my car so much that I couldn't believe such a small change (3mm) could make such a difference. The width of the sway bar determines how much lean the car is allowed in turns. Small bar, lot's of lean. Big bar very little lean.
To answer your second question, plan on spending a good few hours replacing and installing your sway bar. IPD's front sway bar is 25mm 3mm larger than stock and comes with new hardware to change out your stock parts with.
Brian
