Replaced the MAF in the wagon after troubleshooting a million other things for random stalling. Me in my infinite knowledge decided that since the previous owner replaced the MAF 6 years ago (with receipts) SURELY that wasn't the issue.
Narrator: "It was the issue."
Runs great now.
- MrTomLegit
- Year and Model: 1995 850 T-5R Wagon
- ZionXIX
- Has thanked: 65 times
- Been thanked: 194 times
Time to sandblast and re paint that shell and build a new car.
- ZionXIX
So I took my xc90 head, cams and valve cover to a little machine shop in town that works on aluminum parts exclusively. They told me the valves were all straight and only needed cleaning and a valve job. All in they are charging me $450 including the cost of new seals. Also they somehow had a 24 hour turn around on this.
- Sveedy
- Has thanked: 417 times
- Been thanked: 457 times
^ Never seen one taken down so completely. Good job !!
1999 V70 GLT
1999 V70 GLT
- Has thanked: 1504 times
- Been thanked: 3817 times
That’s indeed worthy of the official MVS “ picked clean” award…
- 2B231D65-5F71-43BF-A85B-21E9E814DC80.png (3.49 MiB) Viewed 298 times
- Sveedy
Well I installed the undercarriage brace today, and after taking it for a spirited drive that included a few roundabouts, it does feel stiffer.
Most noticeable in tight turns, but feels better overall. Ended up painting the mounting points black ( thanks to Bob Morton ), so it matches the strut tower brace better.
1999 V70 GLT
1999 V70 GLT
- Has thanked: 1847 times
- Been thanked: 1710 times
Good to know you have noticed a difference! I like the 2 tone look as it matches the black of the standard mounts.
- Sveedy
Yes, I was surprised that it made a noticeable difference. But I guess if you welded a sheet of steel to the bottom of the car, you would feel a difference too. Bottom line - it's a worthwhile upgrade if you can snag one from a junkyard.
Side note; I ended up using the hydraulic press to put a little flat spot in the IPD exhaust pipe for clearance. More controllable, much quieter, and less medieval than using a hammer.
1999 V70 GLT
1999 V70 GLT
