2010 xc70 t6
Third generation Volvo V70 wagon and XC70, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
jhs522
Year and Model: 2010 xc70 t6
2010 xc70 t6
Post by jhs522 »
I recently purchased a 2 owner/low mi (67k) 2010 xc70 t6 & had to replace the battery. I need to register & plate the car but have to emission test it & of course (had this happen w/another xc70) have to do the drive cycle to get it to pass. It’s an extra car & don’t use it a lot but has logged over 500 miles since new battery. Travel has been mostly neighborhood but realize I need to drive it longer & further. Any hints or suggestions out there? Thx you
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 115 times
Been thanked: 185 times
Post by pgill »
It is not clear from your post.
Do you have and ODBII code reader that can check the drive cycle status?
If you don't then my recommendation is get one first and then you can post here which monitor is not ready.
I had to use the drive cycle shown in this thread to get my Audi to reset all of the monitors. You can try it if you like.
https://forums.nasioc.com/forums/showth ... ?t=2872867
The difficult part is slowing from 55 mph to 20 mph without Braking and the end where you slow down from 60 to Zero without Braking.
Good luck
Paul
BlackBart
Has thanked: 927 times
Been thanked: 885 times
Post by BlackBart »
Drive into a big headwind!
jhs522
Post by jhs522 »
I’m in az & emission test says catalyst & o2 sensor not ready. Egr & heated o2 ready. I just need one of two to be ready to pass, fyi
pgill
Post by pgill »
The Chart shows what is needed
- The Engine is cold
- Turn it on and run at idle with defroster and AC on for 2.5 minutes
- Accelerate using 1/2 throttle to 55 mph
- maintain 55 mph for 3 minutes
- Slow to 20 mph (do not brake!!!)
- accelerate to 60 mph using 3/4 throttle
- maintain 60 mph for 5 minutes
- Slow to 0 mph (do not brake!!!)
- turn off the engine
The brakes are not used any any point in the cycle
I drove my Audi for over a year and my monitors would not show ready until I did the cycle exactly as I wrote above
It never happened by accident in over a year.
Good luck
Paul
