FireFox31
Has thanked: 158 times
Been thanked: 300 times
Post by FireFox31 »
scot850 wrote: 18 May 2023, 20:22 Well some forward progress on the dash repair on the R. Finally had everything I needed to start repairing the 'spare' lower dash.
Writing up all of your dash repair work in a single thread would be hugely valuable. Considering how involved your job is, it probably covers every repair anyone could do to their dash. I know it would help me when I eventually pull my dashes to repair them.
Is it possible to drive without the dash pad in? Connect the steering wheel, airbags, instrument cluster, etc? Or, more realistically, is the car vulnerable to water intrusion with the dash pad out? I could pull my dash for a week but the car is parked outside.
FireFox31
Has thanked: 1500 times
Been thanked: 3812 times
No risk of water intrusion but I don’t think you can drive without all the electrical ss connected. The passenger air bag will also be inop.
Has thanked: 1839 times
Been thanked: 1709 times
The passenger airbag is attached to the dash pad. You might be able to carefully remove it, but it will throw a code without it connected and as Abscate says, it then disables your airbag system until it is connected and the code reset.
There used to be a really good write up on dash removals, but currently I can't find it.
I may not get all the photos I need for a comprehensive write up as I am way behind getting the car back up and running. I have a friends 850 waiting for a water pump and I need to get the R out of the way of the hoist to do that. I'll see what I can do though.
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
FireFox31 wrote: 21 May 2023, 18:09
Three parts
FireFox31
Post by FireFox31 »
foggydogg wrote: 21 May 2023, 20:59 Three parts
Thanks. I'm so old fashioned preferring books and forum posts that I always forget to check for videos.
FireFox31
jsrnsis
Year and Model: P80 enjoyer
Has thanked: 25 times
Been thanked: 68 times
Post by jsrnsis »
When I drain my 98 V70XC transmission, only 3 liters of atf come out each time. I put 3 liters back in, and it shows up at the top of the "hot" mark on the dipstick.
97 850 GLT and 94 base model, a little over 3.5 liters come out, put 3.5 liters back in, and it shows up at the top of the "hot" mark. Any reason for this? 98 doesn't have any problems shifting, but I don't know where the half a liter difference comes from.
1998 V70XC black 183xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
I think you have to drive it, and hold it in each gear for a bit, in order for the fluid to fill all the passages and cavities. On my P2, I topped it off twice after a drain & fill.
jsrnsis
Post by jsrnsis »
Also found out my torque wrench was 11% off compared against a digital torque adapter and not accurate at all at that 12-20 ft lbs range Volvo loves to use. Now I'm a bit worried about the 40 13 ft-lbs cam cover bolts I used it on...
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
foggydogg
Post by foggydogg »
jsrnsis wrote: 22 May 2023, 12:29 Also found out my torque wrench was 11% off compared against a digital torque adapter and not accurate at all at that 12-20 ft lbs range Volvo loves to use. Now I'm a bit worried about the 40 13 ft-lbs cam cover bolts I used it on...
For some of those lighter torque figures I usually use an inch-pound wrench. While not proven by scientific method, my guess is that a torque wrench tends to be a bit more accurate in the upper half of the range.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
I believe the upper and lower 10% or so of a torque wrench's range is where you'll have less accurate readings. Particularly in the lower 10%, I would think. At least for a spring/click-type.
