'90 760 A/C-Heater quit
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
volvoaddict007
Year and Model: 760 Turbo
Post by volvoaddict007 »
'90 760 Turbo w 270k. A/C-Heater fan has quit twice in the last 2 months. After shutting off the engine and restarting, the system would work fine. Yesterday it refused to come on even after multiple restarts. It also happened to be one of the hottest days of the year in Los Angeles at 97
1990 5 speed 760 Turbo Wagon 310K.
( '91 940 turbo eng. + trans.)
Konis, diesel springs, 2.5" exhst., 850 T5 wheels
1993 300ZX 2+2, 171K
1999 Ford Windstar LX, 90K
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Don't think so....same system on my 240 and it reads fuel and engine...believe that's it. If you notice only 2 of the plugs have any wiring to them.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
The 760 should have Electronic Climate Control which has self-diagnostics built in.
The 240 should have a Manual Climate Control.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
volvoaddict007
Today I could hear the fan running on one of the slower speeds even when the fan speed was on 0 and no air through the vents and the A/C ( blue snowflake and compressor ) wasn't coming on either.
Seems like the ECC has taken a turn for the worst. Does that make sense? :roll:
BTW, Hi guys. I've been away for a while. Thanks for the responses.
volvoaddict007
Turns out that #19 ECC fuse was blown. I can't believe I didn't think of looking for one as I was only thinking about the blower fuse which was OK. So I swapped out an ECC from another car that was known to be functioning correctly.
The fuse is still blowing :? .
volvoaddict007
Problem solved :P .
A bad fan blower motor was causing the ECC #19 fuse to blow.
billofdurham
Thank you for the update.
Bill.
Previously:
