Fuel pump does not seem to be priming 08 S60 Topic is solved
Has thanked: 1609 times
Been thanked: 4065 times
The only commonality on your starting and cranking is the ignition switch. The P2 platform ignition switch is much more robust than the P80
Get your cranking problem solved and then we can circle back on your fuel delivery
