Has thanked: 2209 times
Been thanked: 1852 times
Good luck!
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
ABV01V0 wrote: 01 Jun 2023, 20:26 Thanks, I’ll get the head off and work on getting it rebuilt, will see how long that will be.
Just as a reminder, the timing mark on the crank is NOT set at number one piston at the top of its' travel.
Has thanked: 1611 times
Been thanked: 4072 times
abscate wrote: 29 Apr 2023, 18:20 Ah, the infamous water pipe M6 bolts. It’s much easier to put it in with the exhaust manifold off the car
Up the game to some Tektron sockets for that M6 , Pittsburghs and Kobalts are ok, but they will break on a tough application
Tektron, Matco, or snap on if you are loaded
You can get a straight shot on them with the right length extension. Use a six point to get a good fit
Here are the tools for water pipe m6 bolt removal. On the RN engine
Top, just a 10mm deep socket
Bottom, SMSLL extension plus socket.
See scale for lengths.
Knocked down in 3.5 hours. Got stuck on one bad buy down pipe, so pulled the manifold off instead. THats gets head to shop, I’ll deal with down pipe later
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
Burnt indeed
Eek!
Today started putting the car back together (friends 850 with knocking engine = failed water pump bearing). Car was running but now added coolant and started the burping process.
Following the removal of the spark plug socket rubber jammed over #4 spark plug, the plugs were all cleaned as well as the wells and re-installed and torqued (not finger tight as they had been).
Decided to check the MAF which is a different item to the P80 ones I am used to. It is just a slide in item. I was going to remove it and clean it, but found the connecter was badly furred up with corrosion. Gave the connector a good clean. Then noticed the IAC connector was not sitting right as someone had managed to bend the spring lock on it on one side. 15 mins faffing around to straighten and then clean and refit.
Topped the coolant up again and started the engine. Now runs well, revs well and no more stumbling when revs are dropped to idle!! Yay!!
Need to d some research on the trunk lid lock. It is seized. I believe it is probably the 2 x detente ball bearings have seized up with muck. Now just need to look up how to remove it and see if I can open it up for cleaning. If the 2 balls get full of muck, then they can't compress to allow the barrel to rotate.
This explains the issue but not how to actually remove it from the car.
Now cleaning and refitting various engine covers. Then onto fixing various loose bits of trim, re-rivet one of the limit stop pads on a control arm and finish the parts list for the owner who is dropping off the summer rims to fit. Oh, still also have to pull the rear hub to check what is needed for the parking brake. Hope the car will be ready to go back on Wednesday and then we can discuss further how far the remaining running repairs need to go.
Abscate, working on the list for Skandix!!
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
Very Good! I knew you'd figure the rest of it out, after you found that rubber piece on the plug.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
FireFox31
Has thanked: 159 times
Been thanked: 303 times
Post by FireFox31 »
abscate wrote: 04 Jun 2023, 10:19 THats gets head to shop, I’ll deal with down pipe later
Looks like that valve is missing a chunk. Is that what we all mean by a "burnt valve"? Does it cause loss of compression?
I want to tear apart a white block engine to learn how it all works. I'd like to eliminate engine oil burning and leaking on my cars, so it seems like engine disassembly and rehab will be required.
FireFox31
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
FireFox31 wrote: 05 Jun 2023, 23:32
Yes, no compression when the valves aren't closing - double so when it's partially missing. It isn't a Volvo if you aren't at least leaking from the oil fill plug gasket. =)
2023 Lexus RZ450e -66k
wizechatmgr
Went out and attempted to convince myself I should work on either or both Volvos today. Did not succeed. Went back into house. Bad me, very bad... 10 lashes for that! I worked the whole weekend so I guess I get to give myself a pass...
My theme song lately:
https://www.youtube.com/watch?v=Vqbk9cDX0l0
To do list:
Replace fubared ABS sensor connector
Stop corrosion on tailgate, perhaps prime afterwards
Fix split CV boot
Replace my XCs auto tranny mount
