Never noticed this before. Piston size for each cylinder stamped into block
All size D on Shagg.
P80 engine cylinder bore marking
- Has thanked: 1502 times
- Been thanked: 3817 times
- IMG_5036.jpeg (1.03 MiB) Viewed 516 times
- IMG_5035.jpeg (529.09 KiB) Viewed 516 times
- IMG_5038.jpeg (778.22 KiB) Viewed 516 times
- BlackBart
- Has thanked: 927 times
- Been thanked: 884 times
100,000.......
or five D's I suppose, just in case you ordered the wrong number of pistons.
It looks like the 1 denotes the passenger side and then each piston size is denoted by a letter for each of the 5 cylinders.
In Shaggs case, D D D D D
Piston size info here…you can order them in size C D. E to match original, or oversize pistons if you have bored out your block
- E4AA8CF8-5063-4F9D-BBFF-C4576A9984BA.png (449.62 KiB) Viewed 473 times
- befarrer
- Year and Model: 1998 V70 AWD
- Been thanked: 24 times
I don't think there would be any bore size differences on a factory built motor, but there would be weight differences. So I would guess the letter indicates weight of the piston. Most OEM engines have a rather large margin of error for piston weights, Volvo must have had tighter specs, and just machine off a slight bit of weight on the crank to match the piston.
98 V70 GLT AWD
05 VW Golf TDI
93 Mazda B2200 with 13B rotary engine swap
05 VW Golf TDI
- Sveedy
- Has thanked: 417 times
- Been thanked: 457 times
So now I'm curious. Part of the point of " mass production " is standardization of parts, so why would factory engines have 3 different sizes, or weights, of pistons ? Different engines, sure. But if we're just talking about the B5234......
1999 V70 GLT
1999 V70 GLT
- befarrer
https://www.speed-talk.com/forum/viewtopic.php?t=22423
http://www.kangamotorsports.com/blog/piston-balancing
I'm assuming the stock pistons are cast aluminum. Some might be slightly thicker or denser than others, making them heavier if machined the same. Think of a flywheel, or even a car rim, they need weight added or taken off of one side to balance it because the casting is heavier on one side. Volvo probably went to extra lengths to keep the weights the same for less vibration and smoother engine. I bet the rods have letters on them too.
98 V70 GLT AWD
05 VW Golf TDI
05 VW Golf TDI
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 129 times
There is a range for good parts during machining. They're not all the same. I've never been involved with grading within that range, but I've heard of it before with engines/cylinders.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Been thanked: 1000 times
It is a common practice of better engine design to sort pistons by size (diameter). Even the best machine practices will produce a small variation in size. By sorting and matching the engine gets a better, more uniform fit of piston in bores. Citroen may have been the first to do this. Honda was doing it by late 1970's.
- Sveedy
As usual, eggs of knowledge cracked on this old bald head
1999 V70 GLT
1999 V70 GLT
From Swedespeed, unverified
Corrected below post by jreed
Measure 12mm from bottom of piston skirt.
C=82.950-82.960
D=82.960-82.970
E= 82.970-82.980
0.01mm translates to 0.0004 inch or 0.4 thou in machine talk, so these are small differences in piston diameter to match variations in engine bore size
They all use the same piston rings as you would have to set piston ring end gap to spec on a rebuild to fit parts
C=82.950-82.960
D=82.960-82.970
E= 82.970-82.980
