With the rear subframe permanently lowered 5/8" (via spacers) I still was unable to disconnect rear hoses from the canister. My hand barely fit there and I can't sufficiently grab the connectors. So when the time comes, I'll be lowering the subframe to get to the canister. Heck, I'll drop it and replace all the bushings
XC70 2001 Evap J hose RR
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 606 times
Re: THE CORRECT WAY TO REPLACE THE J HOSE ON A XC70
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 113 times
- Been thanked: 115 times
Yes; a general consensus is that the J hose life is 100,000 miles.
- packetfire
- Year and Model: 2010 v50 2.4i
- Has thanked: 17 times
- Been thanked: 30 times
A REBUTTAL To The Purported "CORRECT WAY..."
I had the same annoying problem, and yep - Volvo hides that evap canister and J-Hose in the WORST possible place on v70s, atop the rear axle, which COULD mean removing exhaust. But fear not, fellow Volvo caregiver - you are FAR SMARTER than to be so bold as to pull apart the exhaust, as you know that it will only end in tears, writing checks in large amounts, and so on.
Leave the exhaust alone! Yes, you'll need a lift, but loosen the bolts that hold that SUBFRAME (see photo below, outlined in red), drop it down a bit, and get the guy with the smallest hands (perhaps enlist a small child in the effort) to reach in and do the surgery to remove and replace the hose. Before he reaches in there, you need the two BIGGEST guys prying down with big fat pry-bars so you can slide in some nice fat scrap steel to keep the subframe jammed "open". Angle iron, inserted in the orientation of the letter "V" worked very well here. We used 4 pieces. "Safety First!"
(This is properly called "Laparoscopic surgery", as that's for gastrointestinal issues. "Arthroscopic surgery" is for joints, and an evap hose is clearly gastrointestinal".)
That's it! In and out in less than one hour total, The evap canister stayed where it was, and no exhaust components were harmed in the making of this film.
1982 240DL: Drove it 32 years and 1.5 million miles (sold, even still had mint leather!)
2001 v70 2.4T: The most expensive $1500 car I ever bought ("Volvo Turbo" - what an oxymoron!) (sold)
2004 v70: Far less fatally-flawed v70 - It served well (sold)
2010 v50: Smaller, slightly sportier wagon. Its got a spoiler, so I upgraded with sway bars!
- packetfire
It is hard to see without one of those cameras on a cable that connect to phones and PCs you can buy from China for $15, but the TEST is actually easy - VIDA has a whole test sequence to check the EVAP system, and if the evap system is leaking, you'll have a check engine light and a "major leak in EVAP" code thrown.
You or a mechanic can also "smoke test" the evap system (lots of videos about this, and lots of homebrew smoke test machines to make), but I am not sure you will be able to see the smoke coming from the J-hose place where it typically fails (right at the evap canister) unless you first pull down the sub-frame as a I mention above or start removing exhaust components.
If it ain't leaking don't fix it, but if you are replacing exhaust components on a high-miles car (250K an up) I'd replace that J-Hose on general principals while it is easy and cheap to do so. Old rubber is not a good bet.
- Has thanked: 1505 times
- Been thanked: 3818 times
I’ve probably gone through three J hoses on my p80s but my one
P2 is still on the factory original from Ghent in 11.2004
I don’t think these die as often as the p80
- BlackBart
- Has thanked: 927 times
- Been thanked: 884 times
Well presented, Mr packetfire.
The enlistment of s small child is a trick I hadn’t thought of!
I’m at 140k on an ‘04 XC70.
xHeart
Why aren't exhaust made with exhaust grade PVC such as Schedule E?
- 13 Replies
- 6030 Views
Last post by VolvoBoron
- 80 Views
Last post by cn90
