I'm considering taking out the plastic junction-o-ring assembly and just run some 5/8" hose off the aluminum tubes through the firewall. Maybe use some non-hardening Permatex sealant then cinch them with band clamps. The hoses can be installed and clamped on the floorboard or workbench, then just run through the firewall and trimmed and fitted with necessary 5/8" 45 or 90 degree double barb fittings and short lengths of hose to complete the fun.
I'll leave the exterior cover plate in place and seal around the hoses on the engine side with plumbers putty.
Any suggestions?
Volvo 850 replace firewall plastic union 3522035 with hose—anybody?
- Been thanked: 4064 times
… after all that research get part
3522035
From FCP , $60 shipped
3522035
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
I did away with the inner plastic / o-ring contraption, kept the outer part and the seal, and just attached a set of IPD silicone hoses to the aluminum tubes with hose clamps. Haven't had any issues.
1999 V70 GLT
1999 V70 GLT
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
Got it. Curiously, the search on MVS didn't find it, but Google found in on MVS. Maybe just needed the hyphens.
Here it is;
https://www.matthewsvolvosite.com/heater-core-fix/
Nice writeup and pics. Some fussy work, but not very technical and probably less prone to problems than the OEM.
QUESTION: Why not use the full length aluminum tubes, just slide the hoses on to the ridge, maybe with a little sealant, and clamp them.
Then just feed the new hoses through the gutted housing. Am I missing something? I can see how trimming off the flanges on the engine side provides a bit more room for reconnecting.
Comment? I've seen soft, flexible preformed heater hoses at Advance Auto, which I'd thought of using. Some have non-kinked bends and could be cut to fit. Any thoughts about that?
Here it is;
- Sveedy
That's what I did.JimBee wrote: 24 Jun 2023, 17:09
1999 V70 GLT
1999 V70 GLT
- Has thanked: 311 times
- Been thanked: 817 times
As mentioned in OP's post from a month ago (viewtopic.php?t=102225):
I ran hoses to the pipes for a few years (viewtopic.php?t=46253), has pros and cons, but finally went back to the coupler. Some additional comments in viewtopic.php?t=98579.
If you do it I'd recommend use a heavy-duty hose, the soft kind os more likely to collapse.
JimBee
Thanks for the tip!erikv11 wrote: 24 Jun 2023, 18:22 As mentioned in OP's post from a month ago (viewtopic.php?t=102225):
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
They used to make stainless springs you could install on the ID of the hoses to keep them from collapsing in bends - we used them in agriculture all the time.
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
+1 on the springs, but I had trouble sourcing the correct ones locally. I just replaced the broken coupler in my V70 with straight through heater hoses. Which reminds me I still need to make a gasket for the hole.
I cut the metal pipes back to the core to make swapping out a new core easier next time.
The one heater hose is an easy run without any crazy bends, but the other will require a near 90 degree bend to work.
Personally, I think the best way is to replace the coupler section with heater hose, then at the junctions use 90 deg fittings, and replace the hoses to the engine with the silicone heater hose kit from do88.
Knows enough to be dangerous
- 589 Views
Last post by erikv11
- 654 Views
Last post by KD510
- 789 Views
Last post by Nellys80
- 833 Views
Last post by ZionXIX
- 1866 Views
Last post by bmdubya1198
