XC 90 2007 AUTOMATIC
manovlov
Has thanked: 620 times
Been thanked: 143 times
Post by manovlov »
Hy Guys,
I have a question. Friends of mine have a XC90 from 2007. The steering lower hose has a hole and looses fluid. Friends woiuld like to replace theme (both hoses).
Is it the normal way to do to get the subframe down for this operation or can it be done without this step ?
Thanks to all who will explain me the best way to do.
Manov
manovlov
Post by manovlov »
May someone have an idea on this question ?
Thanks Guys.
ggleavitt
Year and Model: 06,08 XC90 V8
Has thanked: 23 times
Been thanked: 125 times
Post by ggleavitt »
I don't believe that you can. The rack bolts to the subframe and the hoses have a rigid part that runs along the rack on the back side which means between the front subframe member and the side of the motor is all the in place space you have to work. See visual for a 5 cylinder, not sure what motor you have but this probably the most simple of the layouts;
5Cyl Steering Rack Hose Route.jpg (40.41 KiB) Viewed 401 times
2006 V8 Ocean Race #740/800 200k, 2008 V8 Sport 183k
manovlov
Post by manovlov »
Thanks ggleavitt. Does it mean that to access to these hoses, the only way is to unbolt the subframe ?
ggleavitt
Post by ggleavitt »
I believe that the only way to replace those hoses is to drop the subframe to some degree. I don't see how you'll be able to do it otherwise.
manovlov
Post by manovlov »
Thanks so much.
Krons
Has thanked: 193 times
Been thanked: 202 times
Post by Krons »
FYI that the P2 subframe bolts are single use and should be replaced with new. A good time to put in new OEM subframe bushing in that are reasonably priced. Verify the torque turn values, if I remember right on my S60 it was 88 ft-lb + 120 degrees.
08 C702.5T (sold)
The non-Swedes:
