Took serpentine belt off to replace, neither old nor new belt will go back on
XC70Rider
Year and Model: 2007 XC70
Has thanked: 35 times
Been thanked: 41 times
Re: Took serpentine belt off to replace, neither old nor new belt will go back on
Post by XC70Rider »
vtl wrote: 29 May 2019, 17:25 I install 1841 mm Volvo belt with one hand, and it is not hard at all. For Conti I had to lock the ratchet holding the tensioner in max position and use both hands.
I've only installed Volvo serpentine belts twice so with less experience just took more effort.
The Volvo 30731808 belt is no doubt a softer rubber material than the Contitech 30731808 belt.
prwood
Year and Model: 2001 V70 2.4T
Has thanked: 9 times
Been thanked: 22 times
Post by prwood »
toddball wrote: 15 May 2019, 16:31 Thanks all for the replies, will try again this evening. Replacement belt is a Duralast, which I guess is not a great replacement either.
Did you have any luck?
Cars I've owned:
Has thanked: 1504 times
Been thanked: 3817 times
FCP has a tech note on using the longer sweep belt on the -1998 engine and moving the position of the idler pulley to reroute the belt for better fitment. I’m mobile and will trying to find and link end of day
Krons
Has thanked: 193 times
Been thanked: 202 times
Post by Krons »
Recently did a serpentine belt on a 02 S60 2.5T, Conti CON-6DK1841 was quite tight but with full swing on the tensioner did get it on with a bit of a fight.
I did order a Goodyear 6DPK1841 off Amazon earlier as I was in a rush to get the car back to my kid. When I found the tensioner bearing rough returned it so I could order the Conti belt and INA pulley. Goodyear belt did appear super tight when I attempted installing, had some poor reviews too.
08 C702.5T (sold)
The non-Swedes:
