Vida CEM swapping
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Re: Vida CEM swapping
Post by vtl »
jeffbolem wrote: 10 Jul 2023, 09:27 Okay, so the only way to get the pin off of the brick cem is to read the flash memory directly off of the chip? Like the diagram Luke posted on pages 218-220?
Yes. Or blow away the chip with hot air and read it in a chip programmer.
jeffbolem
Year and Model: 2004 v70R
Post by jeffbolem »
vtl wrote: 10 Jul 2023, 09:32 Yes. Or blow away the chip with hot air and read it in a chip programmer.
Okay thanks sm. Luckily I have an extra brick cem to practice on.
oscilloscope
Has thanked: 27 times
Been thanked: 11 times
Post by oscilloscope »
jeffbolem wrote: 10 Jul 2023, 09:42
Its far easier and simpler too use usbjtag to connect too the back on the module instead of removing the flash chip considering its buried and annoying too get too. As far as I know the usbjtag tool is cheap for what it can do.
jeffbolem
Post by jeffbolem »
oscilloscope wrote: 11 Jul 2023, 06:04 Its far easier and simpler too use usbjtag to connect too the back on the module instead of removing the flash chip considering its buried and annoying too get too. As far as I know the usbjtag tool is cheap for what it can do.
I was just going to use a microcontroller and use Luke's code from page 218 to read the flash memory on the chip, since I already have a microcontroller. The usbjtag tool looks dope but I don't really have 500+ doll hairs to spend on that right now
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 175 times
Post by dikidera »
Does the Chinese clone ELM327 support more custom commands? Its a nice tool when in a pinch but does not show etm throttle position.
In simpler terms, 7A A6 13 37 is for TPS1. The reason I am asking is because I have my suspicions that my Magnetti Marelli ETM might be in the initial stages of failure.
By driving with the little dongle I can at least verify if the tps1 and 2 diverge in any meaningful way.
UPDATE:Turns out TPS1 and TPS2 are not implemeneted on the Denso Bifuel ECU. I wonder what else I can use. The direct ETM commands don't seem to be documented.
oscilloscope
jeffbolem wrote: 11 Jul 2023, 21:08
What? 500!! That's gone up considerably since last year!
oscilloscope
I'm not sure which usbjtag you're looking at but I just checked on there site and it's $65
vtl
Post by vtl »
oscilloscope wrote: 12 Jul 2023, 09:17 I'm not sure which usbjtag you're looking at but I just checked on there site and it's $65
$65 is a lot of beer! :) Arduino is like $5, and it's a great chance you have one laying around.
oscilloscope
vtl wrote: 12 Jul 2023, 09:57
Yes very true I have a number of them floating around 😄
jeffbolem
Post by jeffbolem »
Jeez, maybe I was looking at the wrong one! That sounds like a much more reasonable price. Im using the Seeed Studio XIAO, which is like 20 bucks for three. They're pretty powerful for their size.
