Even if there were blockage the recovery machine typically uses hoses attached to both the low and high side so all refrigerant will be pump out of the system. You can hook up a recovery machine to only one side using just one hose but it would take a complete blockage to leave something in the system, very unlikely. There's nothing unusual about a Volvo AC system, it's a typical expansion valve type system used by many other car manufacturers.soulvoid21 wrote: 19 Jul 2023, 19:13 He kept getting odd amounts out of the system repeatedly, which is why they think it’s a blockage of some kind. Possibly the valve. He hasn’t had time to look into it further since they last vacuumed and filled the system. But for the cheap cost of the valve, it was easy to just get and replace just in case.
The original AC system, while working fine, was putting a huge load on the engine with the factory 176k mile system. I understand AC puts a load on engines, but you could feel the compressor engaging as it would cycle, far more than it should have been. I’d even lose and gain speed on the highway. So another reason we think there was an existing blockage or worn valve that worsened when vacuumed.
Again he’s not an AC expert, and doesn’t have much experience working with them. He’s only ever ran into issues with my car, and funny enough another Volvo. Which was taken to another shop specializing in AC, but they’re having issues still too apparently.
With the original AC system and putting a huge load on the system, did this just start naturally? No work done on it before you noticed this happening, Is this why you replace the compressor? Any change after the new compressor?
