yanga001
Has thanked: 62 times
Been thanked: 115 times
Post by yanga001 »
Got a faulty signal on the drivers abs sensor. Took some CRC MAF cleaner and cleaned a bunch of electrical connections which cleared up the issue.
2008 S60 2.5T Auto (Sold)
02V70
Year and Model: 2002 V70XC
Has thanked: 53 times
Been thanked: 40 times
Post by 02V70 »
Lots of parts came in the mail a few days ago, and today I spent most of the day working on my Volvo. I replaced the ignition coils, brake pads, rotors, sway bar links, gas cap seal, and transmission mount.
Then I had fun accelerating and braking hard on a rural road to break in the brakes.
2002 v70 X/C 288k miles
TJWookiee
Year and Model: 2006 XC70 CC
Has thanked: 7 times
Been thanked: 10 times
Post by TJWookiee »
Used the Cerakote kit I've seen recommended on this forum on my headlights. Huge difference, photos don't do it justice.
Before
Before
After
After
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
the things I do for my volvo,
got the concrete garage floor all ripped out.
Waiting for a concrete drill so I can install rebar to tie old and new concrete together.
maybe schedule the pour delivery next week.
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
02V70 wrote: 23 Jul 2023, 23:40 Lots of parts came in the mail a few days ago, and today I spent most of the day working on my Volvo. I replaced the ignition coils, brake pads, rotors, sway bar links, gas cap seal, and transmission mount.
Looks like you're really enjoying your XC 70, they are great cars once you get all the bugs out. It seems like you are maybe new to Volvo's so I feel a need to give you some advise if you're changing lots of parts on your car; Buy good quality parts. These cars are very intolerant of aftermarket parts, particularly Chinese made parts. I'm not sure what your situation /budget is or long term plan for the car is but ideally you'll want to use Volvo branded parts wherever possible and yes, they will cost 2 or 3 times as much as RockAuto stuff. Also, keep you're old parts that you change like ignition coils and other electrical or driveline parts that seem ok. You may have some use for spares sometime. As you've already discovered, this forum is invaluable and there are some brilliant people here that can help you find a solution to most any problem you may have.
2003 XC 70 (sold)
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
jonesg wrote: 25 Jul 2023, 16:56 the things I do for my volvo,
Do garage floors have to slope in your area?
Most local municipal building codes require x inch per foot slope for drainage purposes.
jonesg
Post by jonesg »
xHeart wrote: 26 Jul 2023, 12:35
naw theres nothing like that here, you can build almost anything you want,
no certificate of occupancy required as long as you stay off wetlands.
No building permits, no inspections.
Whatever the floor had it is getting the same , i basically cut a very large hole in the floor, didn't remove the complete floor.
Been thanked: 4068 times
You can scare off any building inspector with FAVA beans and a nice Chianti
Hissssssssss
jonesg
Post by jonesg »
https://charm.li/Volvo/
same as all/data.
yanga001
Post by yanga001 »
jonesg wrote: 27 Jul 2023, 12:04 https://charm.li/Volvo/
same as all/data.
AMAZING
