2001 V70 Blower motor comes on with key turned off and not In ignition switch
dchapman
Year and Model: 2001 V70 Base
Post by dchapman »
My 2001 V70 sometimes I park the car and walk away and come back later to find the ac blower running at high speed. This is not the radiator fan, it’s the blower motor. Anyone experienced that, or have a clue what it might be? Twice it ran long enough to kill the battery!
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
It is a feature of the car to cool the electronics. It is normal after a drive in warm weather. However, it should stop after maybe a half hour. A strong battery can handle this. Mine (2001 V70) has always done this as well.
Also, if set the lock the car and the alarm is set, after 2 to 3 weeks even a strong battery will be drained.
firstv70volvo
Year and Model: V70 T5 2001
Has thanked: 52 times
Been thanked: 123 times
Post by firstv70volvo »
dchapman wrote: 22 Jul 2023, 17:09 My 2001 V70 sometimes I park the car and walk away and come back later to find the ac blower running at high speed. This is not the radiator fan, it’s the blower motor. Anyone experienced that, or have a clue what it might be? Twice it ran long enough to kill the battery!
It's to dry out the AC evaporator and to help prevent mold, mildew and bacteria growth in the evaporator, which is what causes the AC air to smell bad. It should not run long enough to kill the battery unless you have older battery on the way out.
dchapman
Post by dchapman »
This is not the radiator fan, that works normally. this is the heater/ac blower motor inside the car
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 114 times
Been thanked: 262 times
Post by Blacklab467 »
It's a feature Volvo calls "after blow" that is used to dry out the evaporator as First70volvo mentioned. The fan can cycle on and off for as much as an hour and can be heard from the front of the car usually after shutting off when the A/C has been used, ie: hot weather as we've been experiencing. I wouldn't describe the fan as being on high speed when this is occurring, maybe low to medium at best.
If you're sure its on high this might be a separate issue. Can you control the fan speed when this is happening? Does this happen when the car is cold?
2003 XC 70 (sold)
KurtL
Year and Model: V70R 2005
Been thanked: 5 times
Post by KurtL »
I used to hear this happen on my 01 V70 2.4T. Now I know why.
dchapman
Post by dchapman »
The blower fan speed is wide open. I have to turn on the ignition key to make it stop. Good question about hot or cold. It did happen last winter too. My concern is that it doesn't stop on it's own like a timed cycle. It will continue running until switch is turned on, or the brand new battery dies.
Thabks to all for assisting with this!
firstv70volvo
dchapman wrote: 24 Jul 2023, 12:55 The blower fan speed is wide open. I have to turn on the ignition key to make it stop. Good question about hot or cold. It did happen last winter too. My concern is that it doesn't stop on it's own like a timed cycle. It will continue running until switch is turned on, or the brand new battery dies.
If the blower motor is wide open and not turning off this sounds more like blower motor resistor may be on its way out.
https://www.fcpeuro.com/products/volvo- ... 90-8693262
dchapman
Post by dchapman »
Thanks so much. That makes sense.
leapdragon
Year and Model: 2007 XC70
Has thanked: 12 times
Been thanked: 31 times
Post by leapdragon »
This feature drives me nuts and I live in the dry, dry desert, so I always disable it in VIDA. But yes, I believe it's the default to have it on.
