Where is my problem coming from... ETM or ECM
adblock
Year and Model: 2001
Has thanked: 5 times
Post by adblock »
Greetings to all readers! I've encountered a slight issue with my 2001 Volvo XC70 2.4T. For over two months, I've been grappling with my throttle body. I acquired two additional throttle bodies - one remanufactured and another from a 250k km-used car. Successfully transferring the software from the original to the other two (all three ETMs now display green on the VIDA software), I've observed nearly identical error codes among them. The behavior of my car remains consistent. Let me elaborate: upon starting, the idle is steady, but there are pronounced explosions that are impossible to ignore on the engine where thé etm IS installed ,The turbo functions well with an audible whistle. However, driving is a dreadful experience due to the configured pops and bangs on the ETM. :oops: Naturally, I've cleared the error codes after each test and have repeated the process several times. I've even disabled the MAF and conducted tests (I replaced it with a new one for the test and visited my supplier thereafter). I'm beginning to question whether the issue lies with the ECM.
I've replaced all five spark plugs, inspected the ignition, cleaned all the sensors, as well as the contactor. Additionally, I've checked the fuses - one of which blew when using the remanufactured ETM. A small query: is it normal for the VIDA software to display certain modules in grey rather than green?
Hère thé code :
Xemodex IS an solution ???
For software transfers I bought transfer tools from zaymon
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
adblock wrote: 21 Aug 2023, 12:22
Here is something that may help https://xemodex.com/us/etm-diagnostic-f ... non-turbo/
adblock
Post by adblock »
hey ,im come back , i followed the procedure to check the etm , and result replacement of the etm , an ETM repair at xemodex will make it work again ?
xHeart
Post by xHeart »
adblock wrote: 22 Aug 2023, 05:26 hey ,im come back , i followed the procedure to check the etm , and result replacement of the etm , an ETM repair at xemodex will make it work again ?
Our 2001 V70XC runs very well on XeMODeX ETM. You may want to email XeMODeX; here is their online contact form https://xemodex.com/us/contact/.
Be prepared to replace all air intake hoses -- big and small -- from air box to manifold.
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
did you replace the etm harness, its a common failure .
adblock
Post by adblock »
xHeart wrote: 22 Aug 2023, 08:23
I'm still not from ETM xemodex, precisely I wonder if having it repaired at home will be a solution for my problem 🫠 or if your not a cheaper solution
adblock
Post by adblock »
jonesg wrote: 22 Aug 2023, 08:25 did you replace the etm harness, its a common failure .
What do you mean by harness? I changed the sensor only
jonesg
Post by jonesg »
the etm plug and wiring, it is the common failure point when disconnected and reconnected, it should be replaced.
Volvo sells the wiring harness with plug. Pull the intake to connect.
https://www.fcpeuro.com/products/volvo- ... ZzEALw_wcB
look up the code 91a7 , it tells you.
Cause:
Something is blocking the throttle position sensor (an oil film, dust etc. )
Poorly charged battery or corrosion in the connecting cables
The power supply to the throttle unit
Defective throttle unit.
This diagnostic trouble code is generated in combination with other trouble codes.
Trouble code ecm 91F0
Cause:
Poorly charged battery or or corrosion in the connecting cables
adblock
Post by adblock »
Wow, I thank you very much, how could I go through this little line, the car has been rebuilt by the former owner I bought them from (broken down because of this etm) a little while ago, do you have any picture of where this faiscaux is located? I will remove the intake this weekend to see more clearly.
Do you know a method to check if the harnesses are functional? Given when your original value?
I could see some diagrams but I can't pinpoint the exact beam? is it this one?
screen of diagram / https://cdn.upload.systems/uploads/dvArAdkO.png
jonesg
Post by jonesg »
I would just change it.
whilst in there , re-route the crank position sensor wire away from the starter motor.
Thats another known cause of electrical problems.
it requires unbolting the starter so be sure to disconnect the battery.
