Has thanked: 1834 times
Been thanked: 1709 times
When I see what people all over the world and in Europe do with their vehicles, what Abscate did is mild. For me the bigger issue is not the getting and staying going, but stopping when the combined load is more than the towing vehicle!
Glad you got her home though!
Had a 'fun' day working in the garage with my Volvo mechanic buddy. We tackled the Fuel filter that looked like it had been sitting in the Titanic. It was a devil to get off. Even thought the filter rotated, it would not release the filter pipes. Gus cut the pipes off and then a combination of vice grips, silicon oil and a lever, the pipes eventually came out. I was right to leave it to the pro!
Filter on and leak free, so on to the 2 x outer tie-rod ends. One had a split boot and the other looked not too bad. I had de-rusted the treads and the nuts on the last visit as well as the ball joint threads. Soaked them again an hour or so before tackling them and they came off like butter! Never seen them come off that easily! In fairness they did not look too crusty.
The surprise was not the play in the broken boot toe-rod, but the other one felt so tight as if it had seized! So glad we did both which makes sense at $30 for 2 x Meyle outer tie-rods. Now the owner just has to get an alignment.
I also replaced the aluminum kick plates that were removed as part of the rocker panel repair work, as well as the from mud flaps.
Final job was to tackle Gus's 97 850 AWD manual. It was due a fuel filter also, but I forgot what a swine they are to do on that and the 98 V70XC!You have to remove all the trunk flooring and the 2 x access panels to have a hope of removing the filter. The front pipe can only be accessed through the front access panel! Fortunately, the pipes both came off easily!
Scary part was, we found the rear sub-frame has a hole in it and a crack coming from it! That brings back nightmares of my R and it's sub-frame. He has threatened me to get me to swap it for him!! :roll: :lol: :lol:
FireFox31
Has thanked: 158 times
Been thanked: 300 times
Post by FireFox31 »
scot850 wrote: 23 Aug 2023, 20:31 We tackled the Fuel filter that looked like it had been sitting in the Titanic. It was a devil to get off. Even thought the filter rotated, it would not release the filter pipes.
Post pics so we can compare it to the Geronimo pinhole leak fuel filter. Mine removed easily enough... as rust and leaked fuel rained down on my head.
FireFox31
Has thanked: 1497 times
Been thanked: 3809 times
Dear Creator,
Why can’t we have nice things like This?
South Canada
850 LPT
Year and Model: 96' 850
Has thanked: 331 times
Been thanked: 242 times
Post by 850 LPT »
abscate wrote: 23 Aug 2023, 18:38
850 LPT wrote: 23 Aug 2023, 18:28 If that V70 has an automatic tranny, check the fluid right away. Replace immediately if dark and burned. I would not be surprised if it overheated.
Trans shifted very well. Torque converter was locking up except on worst hills. Not too worried about it but will check in am
I killed the transmission in our 99'V70XC towing 2000lbs on a hot day when it was only 4 years old. It was a very expensive mistake to make.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
850 LPT wrote: 24 Aug 2023, 06:38
:shock:
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
Uh oh...no more pulling big sailboats then.
Abscate will have to park up his 40ft sailboat!
What is worse than the US not getting manual 850 AWD's, (we did also get V70 manual AWD's), is my friend in Germany has a 98 V70R that came with a manual trans from new!! He keeps threatening that one day it will arrive in a container with his stack of parts to rebuild!
It may not go back.............!
I will take a picture of both fuel filters to show a comparison of a 6 year old, 60,000 mile one and an unknown aged rusty one!
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
Into the breech once more (Actually days ago when it was >90F)
Fast food iced tea and semi-conditioned workspace made it tolerable.
iPhone 7s are notorious for taking junk pics - from new.
Or is that pictures of junk.......! :roll: :lol: :lol:
Those are slightly past their best.
