Fix for broken clip holders on dash switches?
- Grantkat
- Year and Model: 1999 s70 GLT
- Has thanked: 59 times
- Been thanked: 54 times
1999 S70 - does anyone have a fix or alternate way of securing dash switches (such as dimmer) when the plastic slides are broken and wont hold a clip?
1999 S70 GLT ~193k
2014D VIDA/DICE
2007 Jeep Wrangler Unlimited ~ 315K
2008 Lincoln MKX ~130k
2008 Toyota Sequoia ~ 252k
Powered by coffee, stripped bolts, and questionable decisions.
2014D VIDA/DICE
- Been thanked: 4071 times
Perfect junkyard item as the MTBF on switches can be shown to be e^pi + pi^ e or approximately 56 years.
The proof if left as an exercise for the student
Post up which switches you need, I’m unloading stash of unused stuff
- Grantkat
dimmer switch looking for one with both clips intact.
not sure about the MBTF - every unit I see has broken clips
1999 S70 GLT ~193k
2014D VIDA/DICE
2014D VIDA/DICE
- Has thanked: 2205 times
I have repaired them with JB Weld Plastic bond and they are stronger than original. The part runs hot and you are 99% likely to break at least one of the metal tabs off removing one. Really stupid poor design!
Like I said they are stronger than original but still flexible enough to fit. I even 'repaired' any clips that still looked good to prevent them breaking again. Maybe not pretty, but then you are not looking at the repair!
Hope this is of help.
- Grantkat
thats awesome. I just did the same repair...worked like a charm!!
1999 S70 GLT ~193k
2014D VIDA/DICE
2014D VIDA/DICE
- 14 Replies
- 6864 Views
Last post by oragex
- 1699 Views
Last post by Griffe
- 9677 Views
Last post by conotech
- 1290 Views
Last post by erikv11
- 572 Views
Last post by Santore488
