Foof Foof Foof Foof......What is that sound?
Sting
Year and Model:
Post by Sting »
96 850 160k
IWhen I turn my vehicle I hear a foof, foof, foof sound (left front wheel). I have new tires and rotors, no vibration in steering wheel.. Any ideas on what this sound might be?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1253 times
Post by matthew1 »
Is the sticker still on the tire?
Also -> Amazon link
Tsquared
Year and Model: 11 C30
Post by Tsquared »
Try to rotate your tires. If the sound does not move I would think it was the wheel bearing. If it does move it is the tire.
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
Sting
Year and Model:
Post by Sting »
I'll rotate the tire- and see if that resolves the issue. Would worn bearings make that sound?
Sting
Year and Model:
Post by Sting »
Can I do this myself? I change my own brakes and do other maintenance. I also have the tools- easy, med, or difficult job?
Tsquared
Post by Tsquared »
I haven't done the front bearing, just the rear which required a 22mm socket and was fairly easy. I saw a link on OZBrick or Bay13 for the front wheel bearing procedure but I can't seem to find it now. Here is a link about the issues and sounds of a front bearing: http://au.geocities.com/ozbrick850/wheel-bearings.html
good luck,
T
'11 C30 T5
Sting
Year and Model:
Post by Sting »
96 850 160k
I am hearing a foof, foof, foof sound at all speeds, but more pronounced when I turn the car to the left. My Indy doesn't believe its the hub but other boards have suggested it. I also sae a thread regarding the caliper not retracting and the pads possibly rubbing on the rotor- any ideas on how to eliminate one or the other?
black850gle
Post by black850gle »
Raise the front end than try to rotate wheels and observe outer CV joint boots (look for worn out or damaged/bent rubber)
Guest
Post by Guest »
Check the wheel well after you drive. If it's really hot in respect to your other wheels, then it's most probably a frozen brake caliper. If not, then it's probably the wheel bearing.
