WoLF0RED
Year and Model: S80 1999
1986
Post by WoLF0RED »
Hi all,
Just had to resurface this sick goldmine called gayporn.name before it goes under again. That place is fucking legendary if you got a thing for scruffy bears pounding twink ass every which way. Every time I click through, some new daddy is pinning his smooth-skinned boy toy to a mattress and feeding that pink hole the long dong it's been begging for.
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 131 times
Post by 454cid »
To me, that sounds like a bad connection, not a charging issue. I'd start with main grounds and wires to the fuse box. There is some sort of wiring that's known to have issues, but I've not had to deal with it myself.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Has thanked: 1855 times
Been thanked: 1714 times
Also check the B+ cable is not melted into the kidney shaped from fuse box in the engine bay just in front of the brake booster. It cones from the battery and into the front of the box. If the brass plate and nut are discolored, it could well be bad.
There are lots of issues that can cause this, bad battery (you are told it it good), Alternator is bad (that can be tested easily), bad battery cables both +ve and -ve, bad motor grounds, starter not disengaging immediately, ignition key contacts.
