P80 P2 battery size H6 H7 Group 48 49 info ( will H7 fit in p80j
Has thanked: 1503 times
Been thanked: 3817 times
Going to not tempt fate and replace the P2 battery , since it from 2013
:D
Can I use either an H6 or H7 in the standard P80 battery tray? Specs show same height and width, with the H7 being 1.25 inches longer.
I want to use the H7 in Elizabeth , then swap in the bigger battery into the P2 later
ZionXIX
Has thanked: 64 times
Been thanked: 194 times
Post by ZionXIX »
abscate wrote: 17 Sep 2023, 06:03 Going to not tempt fate and replace the P2 battery , since it from 2013
:D
I just bought a new H6 battery from oreillys for the xc90. It's significantly longer than a typical p80 battery. I will measure it later and report back.
jmartin919
Year and Model: S70 GLT SE 2000
Has thanked: 94 times
Been thanked: 39 times
Post by jmartin919 »
I have an H6 in my 2000 S70.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
ZionXIX
Post by ZionXIX »
My H6 battery measures 13.75 inches in length. I compared to my 850 battery location. The only way I can see it would fit is by removing the fresh air snorkel.
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
This is an 096 battery in my 850 which I believe is the same dimensions as the H6
Measures length 278mm x width 175mm x height 190mm (L 10.95" x W 6.89" x 7.48")
Battery clamp is at the last space so H6 is as big as the P80 tray will take and H7 will be too long to fit
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
I could easily fab a battery hold down for the P80 but the P2 bracket is much harder.
P80GLT
Post by P80GLT »
The P2 will easily accommodate a much larger battery. 019 (which I believe is Group 49, H8) fits in at 353mm X 175mm X 190mm, just move the clamp along to the appropriate bolt hole
2010 XC90 SE...SOLD
2005 V70 2.5T SE
jreed
Has thanked: 352 times
Been thanked: 192 times
Post by jreed »
P80GLT... got to say that I admire your battery clip retainer cord. I'm going to do that on mine too!
P80GLT
Post by P80GLT »
jreed: Seen too many fall off and are lost forever, easier to attach a cord and it will never be lost. I also have a cord onto each of my bonnet catches and ever the cable breaks I won't have a problem accessing the engine bay
2010 XC90 SE...SOLD
2005 V70 2.5T SE
Went with the H6 so it fits any of the 4 P80 and P2 in the fleet.
NAPA has a 20% off through September with 2 year warranty in full. Came in under $140 with tax
