Help with vacuum lines!
casualtiererun
- Year and Model: 1998 S70
Looking for the cause of my idle surging and was looking at the brake booster vacuum line and it seemed fine but then I found a missing line from the vacuum tree and a white line running from shroud to manifold (In the pics its just the manifold vacuum nipple), when I connected it to the tree it left a little oil on the tree nipple. I also found a quirky black line that just wasn't connected to anything. Any help is appreciated!
- quirky black line
- 1000000296.jpg (210.5 KiB) Viewed 112 times
- quirky black line 2
- 1000000295.jpg (337.69 KiB) Viewed 112 times
- white line that i think goes to tree
- 1000000294.jpg (144.29 KiB) Viewed 112 times
- 1000000293.jpg (136.16 KiB) Viewed 112 times
- 1000000292.jpg (121.78 KiB) Viewed 112 times
- Has thanked: 292 times
- Been thanked: 765 times
The rubber looks bad in some of your pics, those cracks in the hoses will leak air. I'd consider replacing as many vacuum lines as you can get to, it looks like you have a non-turbo so see viewtopic.php?f=1&t=65002.
For turbo cars look here viewtopic.php?t=63615
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- 16 Replies
- 6479 Views
- 3727 Views
Last post by GreenMagicMan
