Hi,
I am converting a 1998 V70 (base) to fell electric, using a forklift motor.
I am mating the motor to a manual transaxle from an 850. The V70 has an automatic, which will be pulled out with the IC engine.
Question: what CV shafts will work in this application? Re-use the ones that are there? get some from a manual 850? Other?
Project progress at if you're interested.
Thank you.
Dropping 850 manual trans in '98 V70. What CV shafts do I need?
- ThaddeusTheBold
- Year and Model: 1999 S70 T5
- Been thanked: 10 times
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
Very cool undertaking ! I'll be following the progress.
Thanks !
Thanks !
1999 V70 GLT
1999 V70 GLT
- ThaddeusTheBold
I think I have my answer, I went to Rockauto and looked up CV axle shaft kits for my 1998 V70 and also for a 96 850 with an M56 manual transmission (the one I'm dropping into the electric car)... I found parts with the same make/part number for both cars. In other words, it looks like they use the same shafts.
Since the ones in the V70 are pretty much shot, new parts are now ordered... gotta take some risks when you're doing stuff like this, or you never get anything done.
- Been thanked: 4069 times
There is a tabulation of part numbers of axles in this forum by year and transmission. Worth a searchThaddeusTheBold wrote: 05 Oct 2023, 08:54 I think I have my answer, I went to Rockauto and looked up CV axle shaft kits for my 1998 V70 and also for a 96 850 with an M56 manual transmission (the one I'm dropping into the electric car)... I found parts with the same make/part number for both cars. In other words, it looks like they use the same shafts.
viewtopic.php?t=94409&hilit=Axle+tabulation+p80
- 3466 Views
Last post by hausmeister
- 11 Replies
- 4028 Views
Last post by 93Regina
- 571 Views
Last post by Goupil
- 766 Views
Last post by bodington
- 674 Views
Last post by darylrobert
