Since good reman driveshafts are hard to come by these days i am wondering which driveshafts fit which vehicles. Just in case someone comes by a donor at the junkyard or somewhere else, what are the parameters to match so you can expext them to fit.
My guess would be up to 98 and after 98 would be different, as well as manual and automagic. Are NA and turbo different? And then, internationally speaking, there was the diesel 850/V70.
I have no idea about driveshafts on P80 cars, but i guess over time it might be relevant and useful to P80 owners who want to keep their cars running as long as possible.
drive shafts
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
You got the basics, Manual vs Auto, up to 98, 99 up. Also for the passenger side FWD vs AWD. and there are subsets in AWD based on chassis number.
I don't have the actual numbers, but it could be a good research project.
Current Volvos:
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
I think Turbo and NA automatic transmissions are different. Are the driveshafts different as well?
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- Has thanked: 316 times
- Been thanked: 531 times
I don't think the transmissions are different, but I'm pretty sure the driveshafts are.Clemens wrote: 02 Apr 2018, 08:35 I think Turbo and NA automatic transmissions are different. Are the driveshafts different as well?
At least in the US, 2000 model NA automatics have AW55 5 speeds while the turbo models have AW50-42 4 speeds. Otherwise -1999 models all have the same AW50-42.
- FLXC90
I believe the final drive ratio is the only difference in turbo v/NA use transaxles.Clemens wrote: 02 Apr 2018, 08:35 I think Turbo and NA automatic transmissions are different. Are the driveshafts different as well?
Current Volvos:
tryingbe
- Year and Model: None
- Has thanked: 1 time
- Been thanked: 26 times
Rockauto says the auto turbo and auto n/a axles are the same.Clemens wrote: 02 Apr 2018, 08:35 I think Turbo and NA automatic transmissions are different. Are the driveshafts different as well?
https://www.rockauto.com/en/catalog/vol ... embly,2288
Manual axles are thicker from factory.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 276 times
- Been thanked: 84 times
Auto axles are different, in at least for the balancing weight that is attached to the driver side..
I wouldn't buy them from an austrian junkyard btw - I did that once and had to return it - it was bad too. Most of the cars ending up there are already completely worn out.
I'd recommend ordering them from sweden... https://www.bildelsbasen.se - shipping is very expensive, but they have low mileage stuff - might be worth it.
850 T5-R '95 auto
- 568 Views
Last post by Goupil
- 252 Views
Last post by erikv11
- 11 Replies
- 3829 Views
Last post by 93Regina
- 765 Views
Last post by bodington
- 670 Views
Last post by darylrobert
