Vida CEM swapping
minormatt
Year and Model: V70 04 T5 & 05 D5
Re: Vida CEM swapping
Post by minormatt »
Thanks
I thought that was likely still the case.
I guess I need to get a soldering iron out and hope I don't brick the brick.... :shock:
But - thanks very much to everyone here who has been putting in so much effort! Its great to see. If anyone needs to know anything about Transits then I can help :lol: I will put a donation towards keeping the site running for the effort you guys put in and the info I have pulled from it in the past
TonyToronto
Year and Model: 2007 XC90
Has thanked: 5 times
Post by TonyToronto »
vtl wrote: 25 Sep 2020, 08:19 Image
As a Linux kernel engineer I was overthinking the problem. Not all software problems require a rocket science approach. Sigh...
With a kind help from Eastern Europe I've got a CEM dump where ID was found set to zero. Means, Renesas is unprotected. Also everyone there was surprised that I needed an ID to read the flash. Apparently Volvo does not protect M32C and you can freely read it with any BDM programmer that supports that chip. I have a cheap second-hand E8 from ebay and it works fine.
Once you solder the programmer to CEM and have the bin file read - pass it through CEM PIN decode sw, the one I could not understand, and here's your PIN! Which is purely a Volvo-thing applicable to CAN, not Renesas.
The link for pin decoding sw: https://www.digital-kaos.co.uk/forums/s ... -2005-2009
Because Renesas speaks through serial port in boot-mode, all you need is a FTDI adapter/chip to translate between serial and USB, and software like this: https://github.com/fightling/flash-renesas Not necessary to burn a fortune on $xxx BDM programmers like Smoke, or Orange or E8a.
Hi, does anyone have or know where to get the pin decoder software mentioned above? I can't find it at Digital-Kaos. Thank You.
TonyToronto
Hi everyone, after reading about 250 pages on this topic, I think I'm ready to give Teensy project a try. As far can transceivers to order, which are better Texas Instruments or Bosch ones?
Thank You
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
TonyToronto wrote: 15 Oct 2023, 20:59 Hi everyone, after reading about 250 pages on this topic, I think I'm ready to give Teensy project a try. As far can transceivers to order, which are better Texas Instruments or Bosch ones?
Thank You
Any.
vtl
Post by vtl »
TonyToronto wrote: 15 Oct 2023, 20:55 Hi, does anyone have or know where to get the pin decoder software mentioned above? I can't find it at Digital-Kaos. Thank You.
It loads the CEM flash dump and reads the PIN at fixed offset. You can find the pin yourself if you have a dump.
Matuuu
Year and Model: V70 2005
Post by Matuuu »
Where to buy Teensy in Europe?
Cant find correct can transceiver also.
Is it need to be like board or enought to have only chip?
Thanks.
vtl
Post by vtl »
Matuuu wrote: 16 Oct 2023, 05:38 Where to buy Teensy in Europe?
Thanks.
amazon.de?
Chip is fine, if you can solder a PCB.
TonyToronto
vtl wrote: 16 Oct 2023, 05:14
Hi, I have read the flash with programming tool, but having hard time finding the PIN in it. Any idea where i can find the tool?
Thank You
vtl
Post by vtl »
TonyToronto wrote: 16 Oct 2023, 07:29 Hi, I have read the flash with programming tool, but having hard time finding the PIN in it. Any idea where i can find the tool?
Thank You
No idea. What CEM is it?
TonyToronto
CEM-H, from a 07 XC90.
