What is the vacuum required (Hg) to operate the brake booster on these cars?
ThaddeusTheBold
Year and Model: 1999 S70 T5
Been thanked: 10 times
Post by ThaddeusTheBold »
Hi,
Another electric conversion question here for my 1998 V70.
When I delete the internal combustion engine on my V70, I will also have no vacuum source to operate the brake booster.
So, I need to acquire a 12v vacuum pump, and maybe an accumulator tank. They are expensive! So I don't want to buy more pump than I need, but I certainly don't want less.
In order to size the pump, I need to know how much vacuum the brake booster in my car requires. Does anybody here know?
Thank you,
Thaddeus
ThaddeusTheBold
Here is a vacuum pump for a 2006 Volvo S60 turbo. Do you folks think this would work?
https://www.rockauto.com/en/moreinfo.ph ... 5172&jsn=9
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Our P1 C30 uses a vacuum pump also. I think even our 03 S70 T6 has one. Go to any Volvo Parts Online and compare a heavier Volvo suv vs a car's vacuum pump. If they are the same part you should be fine.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
In keeping with the whole “Mathew” theme,
Check out Super Fast Matt on YouTube.
He’s converting an old Jag with Model 3 parts.
He has a couple of videos with conversion
info for power steering and power brakes
using Tesla parts.
And Bonus - Great Channel, 👍
BEJinFbk
Post by BEJinFbk »
Ah! Here we go...
Be sure to watch all the way through to learn about
the less expensive Honda option. Forgot about that.
And while we're at it:
All Hail the Algorithm!
Been thanked: 4067 times
You get about 20 inches of vacuum at most on closed throttle overrun, so you don’t need more than that.
ThaddeusTheBold
Thanks everyone!
