Have you considered fitting S/V70 arms to your 850 instead of the originals? The 850 arms were never that great.
- Has thanked: 1850 times
- Been thanked: 1710 times
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 96 times
- Been thanked: 336 times
Got the new fender installed.
- Has thanked: 1505 times
- Been thanked: 3818 times
Great day! Mom came back! Apparently, she got her last heart at FCP!
What? Too soon?
What? Too soon?
- Has thanked: 927 times
- Been thanked: 1000 times
Eye roll.
- Has thanked: 304 times
- Been thanked: 517 times
I bet that was fun...volvolugnut wrote: ↑04 Nov 2023, 09:09 I used to work for a shop that built liquid nitrogen handling equipment. Because of the extreme low temperature (-320 F), all the pipes had to be stainless steel. Since stainless steel is prone to thread galling, we used Blue Moly thread lubricant. This lube would get everywhere and into the pores of your skin. You tried to be careful what you touched, but still you would get some on you and then it would spread all over you and your clothes.
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 130 times
I was considering that but the information seemed to be inconsistent around that swap. Some seemed to indicate the passenger side S70 arm was needed for for the driver's side 850. Other sources didn't say that, and some said there could be issues with rubbing. Shopping ebay for used S70 arms, they were more expensive than I could get a new aftermarket 850 arm that should at least fit, and work, for awhile.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- xanthefin
- Year and Model: 1997 850
- Has thanked: 106 times
Success after the years own wish after knowing it i did demystified this feature of 850 dashboard and how control it.
VID_20231105_103536063.mp4
Yeah mostly to annoy anyone who loans the car
- Chuck W
Lol.xanthefin wrote: ↑05 Nov 2023, 03:46 Success after the years own wish after knowing it i did demystified this feature of 850 dashboard and how control it.
Yeah mostly to annoy anyone who loans the car![]()
- Sveedy
- Has thanked: 417 times
- Been thanked: 457 times
I ended up switching the wiper arms with those from a Dodge Shadow. I just couldn't deal with how the passenger side arm stood so high above the hood line. Now they both sit down below the cowl. Much cleaner look. I did have to do a little modifying of the drivers side arm.
And I never heard ( or heard of ) a speed warning buzzer. And you could say I have driven it a bit at a clip.
1999 V70 GLT
1999 V70 GLT
- xanthefin
It would be good to know all which wiper arms fits these as 850 are just so weak as stock.Sveedy wrote: ↑05 Nov 2023, 08:28 I ended up switching the wiper arms with those from a Dodge Shadow. I just couldn't deal with how the passenger side arm stood so high above the hood line. Now they both sit down below the cowl. Much cleaner look. I did have to do a little modifying of the drivers side arm.
Speed Warning was activated only for market areas which required Speed Warning so Japanese and Saudi i think only(?) which why if it was seen it came via imports only as stock and installed. It can be programmed chime in kmh 32 up to 284 kmh (284kmh = disabled).
How to retrofit buzzer for 850 models
