Hello, I have the ever popular side-tank crimp leak...
The performers on live sex cams often have unique and creative usernames, adding another level of excitement to the experience.
https://themyfreecams.com/chat/quennacindy
https://porncam.name/chat/saraloverays
https://trannycam.cc/pinay
Thanks.
Radiator swap question
- Has thanked: 1506 times
- Been thanked: 3822 times
Bon jour, Rene
You should tell us which engine you have so we can research this, as well as the engine from the 1996 donor car, merci.
- misha
- Has thanked: 152 times
- Been thanked: 402 times
Radiators are the same...for cars with same transmission and non turbo.
Radiator for a car with auto transmission is different than for a car with manual transmission.
Cars with auto transmission have radiators with 2 cooling lines since one part of the radiator is for auto transmission cooling and the other part is for engine cooling.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
jsrnsis
- Year and Model: P80 enjoyer
- Has thanked: 25 times
- Been thanked: 68 times
If both cars are automatic you can swap them. Automatic radiators have transmission cooler line hookups on the drivers side, if it's a turbo it will have hookups for an oil cooler on the passenger side. You can use an automatic turbo radiator in a non-turbo car. If you still have the oil cooler in a turbo, you must get a turbo radiator.
1998 V70XC black 183xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
- CIK7
- Has thanked: 329 times
- Been thanked: 87 times
I once had to replace the radiator on my previous 98 s base 'GT' 5sp. I could not find a listing specifying the manual model so I tried the new generic 'auto' unit a fellow Volvoist in Broken Bow had on hand. It worked for me. EDIT: I just took a minute to go check the Rotten Tomato's (see 98 v red in sig) radiator. Earlier this year, I totaled the front end and bought the 99 s awd listed in my sig as the donor car. The donor (turbo, auto) radiator was a 100% fitment on the Rotten Tomato.jsrnsis wrote: ↑09 Nov 2023, 05:35 If both cars are automatic you can swap them. Automatic radiators have transmission cooler line hookups on the drivers side, if it's a turbo it will have hookups for an oil cooler on the passenger side. You can use an automatic turbo radiator in a non-turbo car. If you still have the oil cooler in a turbo, you must get a turbo radiator.
Todays forecast, light rain with a 99% chance of….
Ban hammer!
Ban hammer!
