Radiator swap question
ReneG
Year and Model: 1994 850
Post by ReneG »
Hello, I have the ever popular side-tank crimp leak...
The performers on live sex cams often have unique and creative usernames, adding another level of excitement to the experience.
https://themyfreecams.com/chat/quennacindy
https://porncam.name/chat/saraloverays
https://trannycam.cc/pinay
Thanks.
Has thanked: 1506 times
Been thanked: 3819 times
Bon jour, Rene
You should tell us which engine you have so we can research this, as well as the engine from the 1996 donor car, merci.
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
Radiators are the same...for cars with same transmission and non turbo.
Radiator for a car with auto transmission is different than for a car with manual transmission.
Cars with auto transmission have radiators with 2 cooling lines since one part of the radiator is for auto transmission cooling and the other part is for engine cooling.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
jsrnsis
Year and Model: P80 enjoyer
Has thanked: 25 times
Been thanked: 68 times
Post by jsrnsis »
If both cars are automatic you can swap them. Automatic radiators have transmission cooler line hookups on the drivers side, if it's a turbo it will have hookups for an oil cooler on the passenger side. You can use an automatic turbo radiator in a non-turbo car. If you still have the oil cooler in a turbo, you must get a turbo radiator.
1998 V70XC black 183xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
CIK7
Year and Model: 95 854T & V70trailer
Has thanked: 328 times
Been thanked: 87 times
Post by CIK7 »
jsrnsis wrote: 09 Nov 2023, 05:35 If both cars are automatic you can swap them. Automatic radiators have transmission cooler line hookups on the drivers side, if it's a turbo it will have hookups for an oil cooler on the passenger side. You can use an automatic turbo radiator in a non-turbo car. If you still have the oil cooler in a turbo, you must get a turbo radiator.
I once had to replace the radiator on my previous 98 s base 'GT' 5sp. I could not find a listing specifying the manual model so I tried the new generic 'auto' unit a fellow Volvoist in Broken Bow had on hand. It worked for me. EDIT: I just took a minute to go check the Rotten Tomato's (see 98 v red in sig) radiator. Earlier this year, I totaled the front end and bought the 99 s awd listed in my sig as the donor car. The donor (turbo, auto) radiator was a 100% fitment on the Rotten Tomato.
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
Todays forecast, light rain with a 99% chance of….
Ban hammer!
