front brake rotor r/r: do pins/caliper need to come off individually?
ogatrulle
Year and Model: xc90 2008
Been thanked: 10 times
Post by ogatrulle »
It's been a while since I did the brakes on my 06 v70, so can't remember. Maybe someone here knows:
In order to replace the front brake rotor, I know the whole caliper holder has to come off. Can I just take out the two caliper holder bolts (to the knuckle) and pull off the whole thing (caliper holder/caliper/pads)? Or do I have to take out the slider pins and remove the caliper/pads first before unbolting the caliper holder?
Thanks!
2006 v70 2.5T; 2008 xc90 3.2
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
nope, just remove the 2 big bracket bolts, pry the pads back so you can slide the caliper free as you remove it all in one piece.
remove the 10mm bolt and the disk pops off.
Has thanked: 1507 times
Been thanked: 3823 times
It’s the difference between a mechanic and a technician
Technician: removes bolts , pops caliper off, rotor, replaces. One hour
Brake job lasts one year
Post on Fora about bad Volvo brake design
Mechanic. Removes calipers, springs, bolts, rotor, two hours
Spring deforms slightly, so it is replaced.
Piston deal on caliper slightly off place, gets reseated, saves caliper from rusting in one year
Brake pad inspection..wearing slightly unevenly. This means piston is seizing. Replaces caliper , saves new rotor from demise
Cleans and lubes caliper slides for best brake performance
Cleans face of wheel hub for true running of rotor
Uses new caliper bracket bolts per Volvo
Which one do you want to be?
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
abscate wrote: 11 Nov 2023, 06:22 It’s the difference between a mechanic and a technician
New caliper bracket bolts? MVS members are TechMechs, some going the 1.5 while others the 3.0 hour route.
Year and Model: 2001 V70
Has thanked: 928 times
Been thanked: 1002 times
Post by volvolugnut »
Choices will be made by each individual based on mood, finances, other chores waiting, other people waiting, tools and parts available, knowledge, experience, and the current weather conditions.
The older I get, and the less time I have left on Earth, the more I appreciate the job done carefully and completely. Brakes are one of the two most important things to do right, steering being the other.
Here’s a thread where the first picture shows how cutting a corner on a brake job doesn’t pay…
viewtopic.php?t=90075
This explains something that had bothered me a long time. I think I am good at repairs, but I could never be fast enough to make money repairing for others.
ogatrulle
Post by ogatrulle »
On a related topic, VIDA has this note for both my 06 v70 and 08 xc90:
Brake caliper mounting…
Install:
the new brake disc. Tighten the locating pin (5). Tighten to 8 Nm
the caliper holder. Use new mounting screws (4). Tighten to 100 Nm .
No judging here. We have all cut corners on a job because of time money people pressure. But, understanding the job in its completion is important so we understand the consequences.
When I did the rear axle drop on the cat I replaced every single mount bolt and cleaned and never seized the lot. This saved my life when my workmanship failed 200 miles from home, and an Indy dropped it for me 4 hours labor
