Hi,ZionXIX wrote: ↑14 Nov 2023, 06:46MrAl wrote: ↑10 Nov 2023, 11:46Hi,volvolugnut wrote: ↑04 Nov 2023, 11:04 I believe a quality bearing would required grinding to the final tolerances.
Yes that's what they did.
From memory, first the machining to the rough size. Then heat treating in a molten salt vat for some minutes, then quenching. Then there might have been another machining cycle. Then they did 'carbonizing' to the piece, then the final grinding to the final shape.
The carbon adding part I think they call it Carburization.
The heat treating schedule was fairly ridged. The piece went into the molten salt bath and the timer times it for so many minutes then it is removed and immediately quenched. The hardness is then checked on random samples.
Whoa, molten salt bath? That alone puts it out of reach for the DIY person. Doesn't it take several thousand degrees to melt a salt?
Well regular salt probably around 1500 degrees, but I do not know if they had any other additives too.
There are other ways though you can look around the web for heat treating at home. I think you can even add carbon to the outer surface to get the main wear surface even harder. I've never done any of this only the blow torch heating and quenching method part myself. This isn't the main concern though I don't think. The main concern is getting the final part to the exact dimensions. Because of that, I think we would need a higher priced CNC machine than the ones being solve for engraving and stuff like that in order to make something as fine as a bearing. I don't know for sure though I've never had to do that except for very slow moving, low power machinery. For other simpler parts though I would think it would work. For example, parts that don't have to move or move slowly like for the gas pedal linkage, stuff like that. Big parts would have to be made in pieces, welded together and ground down, or bolted together.
I guess the main point this this thread is that if you can't get a part, this may provide a path to success. With my old Hyundai I had to make a part I could not get anywhere, but it did not require any machining, so it was much simpler.
