1994 855 T Vibration at idle
asbard
Post by asbard »
My 1994 850 turbo wagon, in addition to a number of other little quirks, has annoying vibration when stationary, particularly on an up-incline. I had the front engine mount replaced, but it did nothing (in fact seems worse since). Other mounts have apparently checked OK. Any ideas?
asbard
Post by asbard »
I should add that when driving, the feeling I have is as if I was holding a small coffee grinder..
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1253 times
Post by matthew1 »
Perhaps the engine is just running rough. Sparkplugs good? Air filter, vacuum hoses etc.
Also -> Amazon link
Tsquared
Year and Model: 11 C30
Post by Tsquared »
Was the engine mount stock or aftermarket? Did you notice the vibration after the upper mount change or before?
It is my understanding that the aftermarket upper mounts are more rigid and you will feel more engine vibration.
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
asbard
Post by asbard »
The engine feels quite smooth to touch. I will check the spark plugs, air filter etc. just in case.
As to the mounts, the upper mounts are OEM and were changed at 60k miles by the previous owner. The passenger side (low) mount (in reality the front engine mount, because that's where the front of the engine is)was changed recently (82k miles). I was feeling the vibration before the change of the front mount as well. The hydraulic mounts show no leaks, which means they are O.K. according to the mechanic.
