Non-Volvo car chat megathread
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2656 times
Been thanked: 1248 times
Re: Non-Volvo car chat megathread
Post by matthew1 »
BlackBart wrote: 24 Nov 2023, 14:29 Matt - that top one is sweet. What is that?
I think he said a '34 Deuce Coupe.
BlackBart wrote: 24 Nov 2023, 14:29Every car show has a turquoise '57 Chevy with Torq Thrust mags.
'56. '57 had the fins.
BlackBart wrote: 24 Nov 2023, 14:29 I believe Rear Admiral Abscate has a Lotus.
Wow a Lotus. Question for you BB: what's the "tell" in the photo that it's a Lotus?
Also -> Amazon link
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
matthew1 wrote: 24 Nov 2023, 16:10
The top car is a 1935 Ford. They had four bar hood side panels. The next year (1936) had three bar hood side panels. A friend has a nice original example. The side panels were removable for service access. I have a 1938 Ford sedan with yet another side panel design.
A 'deuce coupe' is generally considered as the 1932 Ford coupe. Deuce for two as in 1932.
matthew1
Site Admin
Post by matthew1 »
Ah, I thought it was Fords with that body style. Thanks.
Also -> Amazon link
BlackBart
Been thanked: 884 times
Post by BlackBart »
matthew1 wrote: 24 Nov 2023, 16:10 Wow a Lotus. Question for you BB: what's the "tell" in the photo that it's a Lotus?
He told us. “Elan”. Trick question!
BlackBart
Post by BlackBart »
volvolugnut wrote: 24 Nov 2023, 17:31 The top car is a 1935 Ford.
I like it.
The 1932 Ford was a major design change for Ford. This was the first year for Ford's famous flat head V8. There were V8 engines from other manufacturers, but none in the low price market. The new V8 had all cylinders cast in a common block and valves mounted in the V of the block. Heads had no valves, only the spark plugs, so they were 'flat'. The engine had two water pumps, one for each cylinder bank, mounted on the front. A single downdraft carburetor supplied all cylinders. The distributor was mounted on the front of the engine with the styled coil mounted on top of the distributor.
The 1932 body was little changed from the previous Model A. It was small and light, making it a good candidate for larger motors and performance.
Has thanked: 1505 times
Been thanked: 3818 times
BlackBart wrote: 24 Nov 2023, 22:30
It’s a tough crowd to try and slip one by....
BlackBart
Post by BlackBart »
Hagerty’s Tom Cotter’s cool wagon is a ‘39. I love it. He has quite a history with it back to his youth. Heavily modified, like an LS swap. But he drives it across the country.
https://www.jalopyjournal.com/?p=55747
But I’m really liking that ‘35 nose.
Ford had some great stylists in the late 1930's. After 1940, I don't like them much.
matthew1
Site Admin
Post by matthew1 »
abscate wrote: 26 Nov 2023, 05:50 It’s a tough crowd to try and slip one by....
We were born at night, but it wasn't last night.
Also -> Amazon link
