RedBrickCollector
Year and Model: 1997 850 T-5 Wagon
Has thanked: 40 times
Been thanked: 28 times
Post by RedBrickCollector »
I've come to discover that my BCV isn't bolted in, seems like the previous owner just up and lost the bolts. No real scrapyard options here, and I know it's a longshot but would anyone here know what it would be on say FCP Euro? I can spend the time to find something with the right size and pitch but OE spec is always nice.
Also I'm scheduling a check of the A/C, probably got a slow leak. I've had one other orifice tube based car and I'm wondering if these cars are similar in that the orifice tube itself tends to get clogged and needs to be replaced every so often.
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
Has thanked: 1498 times
Been thanked: 3810 times
bmdubya1198 wrote: 13 Dec 2023, 16:41 Scored a set of Volans on eBay for $100! Even came with a spare Hydra. Picked them up earlier today and combined it with a junkyard trip being that it was a hour away, and 10 minutes down the road from said yard. Grabbed some stuff for my truck and BMWs at the yard, not much of a Volvo selection today.
If you get a flat with a Hydra, put it into the trunk and it will turn into two good spares.
The orfice tubes only get plugged when people use the AC leak crap on them
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
RedBrickCollector wrote: 14 Dec 2023, 02:07 I've come to discover that my BCV isn't bolted in, seems like the previous owner just up and lost the bolts. No real scrapyard options here, and I know it's a longshot but would anyone here know what it would be on say FCP Euro? I can spend the time to find something with the right size and pitch but OE spec is always nice.
When I replaced the evaporator on mine, I replaced the orifice tube and it was almost totally plugged up. It was NASTY. So yes, it's possible that it's a problem. That's what I don't like about refrigerants with added stop-leak. It plugs those right up.
abscate wrote: 14 Dec 2023, 05:47
I'll have to try that...
brunocerous
Year and Model: 1998 V70
Has thanked: 284 times
Been thanked: 36 times
Post by brunocerous »
Successfully removed my ventilated tire off the rim and replaced it with a new Goodyear, but I couldn’t get the bead to seat. The ratcheting strap around the outer edge of the tire didn’t work, and the starter fluid method worked on one side until I tried to stamp out the flames and unseated it. The other side didn’t provide the blast to seat the bead; it was just flames.
Maybe I’ll ask Santa for an air compressor this year!
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
bmdubya1198
brunocerous wrote: 16 Dec 2023, 09:18 Successfully removed my ventilated tire off the rim and replaced it with a new Goodyear, but I couldn’t get the bead to seat. The ratcheting strap around the outer edge of the tire didn’t work, and the starter fluid method worked on one side until I tried to stamp out the flames and unseated it. The other side didn’t provide the blast to seat the bead; it was just flames.
Tell Santa to swing by the ol' Harbor Freight... they have some good sales on compressors right now!
5rivers
Year and Model: V70 1998 T5
Been thanked: 14 times
Post by 5rivers »
I managed to remove the small metal pocket cover to the transmission that encases the dip stick. It had a leak that I was able to stop with a small dap of solder early this summer, but after doing that another pin-sized hole appeared just below the one I closed up! I was able to find a junkyard replacement that seems in decent shape. With the balmy weather we are having (50 degrees F in mid-Dec!), I thought maybe it's time to replace that cover.
Well, let me tell you...I hope I never have to do something like that again!
To gain access to the four bolts holding the cover, I had to remove the transmission mount, and remove the bolts holding the transmission oil cooler line that feeds into the transmission adjacent to the cover! Sounds easy enough, but to get to the bolt holding the cooler line about mid-way to the motor, I had to create more access...removed the battery, the battery tray (and all the parts underneath the tray), the bolts holding the dip stick tube in (without removing the entire tube), one of the turbo hoses leading to the bottom of the condenser, and a few other air/vacuum hoses! My goodness, what a project!
I cleaned off the cover's mating surfaces (the replacement cover and the part of the transmission the cover attaches to (reminded me of cleaning the cylinder head before applying new gasket material!!). My primary concern was being able to get the bolts back in once I had the cover in place...a rightly so...it seemed to take forever. Had to use a quarter inch drive with a 10mm socket and concort my arms in front of and between the subframe and other hoses and electrical harnesses so I could actually hold the ratchet, and then hold the socket so it would tighten the bolt, especially the very most top bolt. Without any tension, the socket goes in the same direction as the ratchet - forward and backward without any tightening action! The other three bolts were easily inserted and tightened. What would have helped was a quarter inch wobble extension, but I have never seen one of those:)
So, my question is....how much time should I give the gasket material time to dry...hours or a day(?) before adding fresh transmission fluid?
Pics below:
dip stick
Here is the position of the ratchet!!
In the above pic, the top most bolt can hardly be seen, but it's there, dark, oily covered, just below the dirty looking oil cooler line!
Very tough to reach, remove and/or install!!
5rivers
1998 V70 M56, silver/grey, has tranny issues, #?# owner, 330,xxx miles, a handy parts car
1998 V70 AT, nautical blue, 2nd owner, 260,000 miles, Sold
1998 V70 AT, T5, forest green, 3rd owner, 172,300 miles, Mimas 16" rims
5rivers
Post by 5rivers »
For gasket material, I used Permatex anaerobic gasket maker - kind of reddish - pink in color.
5rivers
Has thanked: 1836 times
Been thanked: 1709 times
What does the sealer recommend? I'd go by that. Some anerobic products never actually harden fully so they can fill any slight surface imperfections. Without knowing the sealer you have used, I know some here have used the Permatex product so I will leave any shortening of time to recommended to them.
Good luck and well done tackling this one! I did not envy you having to tackle this one!
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
Good perseverance, 5rivers!
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
bmdubya1198 wrote: 13 Dec 2023, 22:55
MoVolvos wrote: 13 Dec 2023, 21:53
Excellent deal. Any good Volvo yards in the RTP area you know of?
None that come to mind, I feel like there are a couple good ones out that way though. I've been to the LKQ in Durham once... actually I made it to the front doors, and they had literally just closed for the day due to a case of covid. This was early on, probably summer of 2020, so at that point it was still a terrifying thing that warranted closing an entire store... I was a bit annoyed, considering it was 2 hours from home and they had stuff I was looking for.
The yard I went to today is 109 U Pull It in Winston Salem. Great yard, lots of inventory and good prices.
Folks live 10 minutes from the LKQ. Just saw it a couple of months ago after driving 70 for these many years :roll:.
