P0420 After VVT seals replacement
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Re: P0420 After VVT seals replacement
Post by vtl »
nliutilitt wrote: 17 Dec 2023, 07:10 Ok, made the VVT adjustments, pretty straight forward. Just had to disconnect battery to reset adaptation before checking it after each adjustment.
Bosch ME7 does VVT test every time engine start. No need in disconnecting the battery.
nliutilitt
Year and Model: 2004 V70
Has thanked: 10 times
Post by nliutilitt »
That's what I did initially, but adaptation didn't reset on engine start and reving to 1500. Almost over adjusted the intake. disconnecting the battery updated the adaptation angles after each adjustment.
nliutilitt
new O2 sensors in... Volvo sure knows how to make it difficult to access.
Signal is still same as before it seems. don't notice any real changes. Old sensors seem alright?
Double checked the hoses buttoning up after VVT seals, all seemed in place. Will check the hoses again in the morning.
old B1S1 sensor
old B1S2 sensor
Has thanked: 1502 times
Been thanked: 3817 times
The OXS get old and slow after 100,000 miles. Visual doesn’t really tell you anything.
nliutilitt
Well, over 300 miles after replacing both O2 sensors, pre and post cat. Still getting P420 sporadically, Once ~200 miles after new sensors. Again just ~30mile after clearing that. Right now going on ~130, with a P0420 pending but not tripped the light yet.
From live data everything seems fine with the O2 sensors at least.
Upstream shows Lambda, so should be 1, or very close to it. Which it is generally, never varies more than +/- 3%.
Downstream passes OBD test, but hovers near 0.1~0.2v, occasionally goes up to 0.7~0.8. when it should be settling to ~0.45v from what I gather.
Otherwise there isn't any power loss or poor MPG.
LTFT looks in order, 0~5%, about normal for this time of year.
MAF looks in order for this time of year
I guess it's either wiring issue or Cat going bad. Not sure what else it could be.
nliutilitt
Got under and checked the temp at front and back of converter. with coolant temp at 90 and idle 650~660 rpm, ~115c entering the converter, and ~90c exit from converter. I believe the exit side should be hotter than entrance side? That confirms cat going bad I guess?
jonesg
Has thanked: 69 times
Been thanked: 479 times
Post by jonesg »
nliutilitt wrote: 22 Dec 2023, 14:14 Got under and checked the temp at front and back of converter. with coolant temp at 90 and idle 650~660 rpm, ~115c entering the converter, and ~90c exit from converter. I believe the exit side should be hotter than entrance side? That confirms cat going bad I guess?
yes, it should react and increase temperature at cat exit.
dikidera
Year and Model: S60 2005
Has thanked: 67 times
Been thanked: 175 times
Post by dikidera »
That idle looks rather suspicious, these engines always idle at 750rpm. Was true for my 4 cylinder p1 volvo and same for 2.4 s60
nliutilitt
This one has been idling at 640~680 for 6 years. varies a little depending on the gas station I last fueled at. but always ran smooth.
vtl
Post by vtl »
dikidera wrote: 22 Dec 2023, 23:56 That idle looks rather suspicious, these engines always idle at 750rpm. Was true for my 4 cylinder p1 volvo and same for 2.4 s60
2.5T idles at 650.
