Is this new designed PCV Banjo Bolt a must replacement per video? My PCV system is working fine but don't know if PO had this replaced already.
Volvo PCV Banjo Bolt - Genuine Volvo 31325709
S60, S80, V70, XC70, XC90
w/integrated check valve
OE check valve damaged cylinder head valves.
https://www.fcpeuro.com/products/volvo- ... vo-8653884
Volvo PCV Banjo Bolt With Integrated Check Valve
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
- 02V70
- Year and Model: 2002 V70XC
- Has thanked: 53 times
- Been thanked: 40 times
I think it is relatively unlikely that it fails, but if it does it wreaks havoc. I'll probably replace it when I do my PCV system. I read somewhere that there are two banjo bolts, but I'm not sure if that is correct.
2002 v70 X/C 288k miles
- firstv70volvo
- Year and Model: V70 T5 2001
- Has thanked: 52 times
- Been thanked: 123 times
There was one banjo bolt version that sometimes had a problem with retaining the integrated check valve in the bolt and if it escaped it gets sucked into the engine, not good. The later revision has a better pin retaining design, it's this one...
If the head of the bolt is stamped with 2014 it's the better design and I've read there are banjo bolts with a later year stamp on them.
My 2001 didn't even have a check valve in it so I updated it with the later version bolt.
There's also a banjo bolt for the coolant flow on the other end of the main PCV hose assembly, I don't know the part number but this bolt has a larger opening for water flow and no valve, I don't know if it even fits on the intake manifold side but I don't think it would be a good idea to use this bolt on the intake manifold.
- MoVolvos
There was some good information in the "Similar Topics" link below.
viewtopic.php?p=576165&hilit=%E2%80%9Cb ... 9D#p576165
I'm replacing a PCV system on a 2002 Volvo T5.
My car has currently the PCV banjo bolt style without any check valve.
Does anyone know if there's any benefit in fitting the new style PCV banjo bolt with a check valve?
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 605 times
Yes. Turbo engine does not have vacuum in intake manifold under boost. Check valve restricts pressure from entering the PCV system, which helps tremendously the other half of PCV, which already struggles to draw sufficient vacuum via the long heated pipe going around the block to turbo's intake.
