How to test and repair your EVAP valve:
This topic is in the MVS Volvo Repair Database » How to Test and Repair your EVAP Valve
songzunhuang
Year and Model: 98 V70 T5
Has thanked: 2 times
Been thanked: 30 times
Re: How to test and repair your EVAP valve: (2023, contains wrong info)
Post by songzunhuang »
Well for my car, this was not the issue. I tried to repair the valve and couldn't tell if it really worked. I was still getting the code. So I bought a new valve. That didn't remedy the code either. So the search continues for me.
Song Huang
1998 V70 T5 - Hurt your eyes red
2000 Honda S2000 - Berlina Black
1984 BMW 633CSi - Dolphin Grey
2024 Lexus - Eminent White Pearl
2004 XC90 T6 AWD Ruby red (RIP)
Been thanked: 466 times
Post by cn90 »
In the original post by "thecheat" (the original poster), he mentioned that you apply 12V then check the vacuum. I don't think this is true.
The way I understand is:
- Engine OFF, the valve closes, you can't blow through it.
- Once the 12V is applied, the valve opens, allowing gasoline vapor to enter the intake manifold.
So, if I am right, then the way to check the valve is:
- Take it out of the car and blow through it, if you can, it is stuck in the OPEN position.
- Now if it is tight (you can't blow through it), then apply 12V, you should now be able to blow through it.
How do I know?
- My 3-yr-old Bosch valve is kaput.
- I have a brand-new Pierburg valve and I compared the new Pierburg vs the kaput Bosch, and these are my observations.
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
Or just leave it in the car, pull hoses, put clean hose on one end, and blow through.
Though, are you saying, then, that the valve is continuously open when the car is running?
- S
[Sold] '97 S70 T5
Post by cn90 »
When engine runs, the valve opens for short period of time during startup and that is it.
oldschoolvolvo
Year and Model: 1979 242DL
Post by oldschoolvolvo »
what is the expected resistance across the terminals for the EVAP valve?
-Mike
Current:
1979 242 DL
1998 V70 T5
1992 240 GL
Has thanked: 1498 times
Been thanked: 3810 times
oldschoolvolvo wrote: 23 Dec 2023, 06:38 what is the expected resistance across the terminals for the EVAP valve?
Depends on part number, year model etc
For the ME7 square type purge valve it’s 27 Ohms but no tolerance is given.
I’ll fact check that , too.
Fact check 29.7 +- 1.4 ohms
I’ve found many cars run fine without ECM codes outside this range, so it isn’t a good diagnostic for definitive failure. It’s a duty cycle controlled valve , not an open/ closed valve , btw.
The first first in this thread might be correct for the referenced BMW m30 but is not correct for P80s Volvo series purge valves.
oldschoolvolvo
thanks I was thinking of the P80 cars
is ~27 ohms still a good number?
-Mike
Current:
1979 242 DL
1998 V70 T5
1992 240 GL
