P80 Oil Cooler Hose Replacement Topic is solved
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Re: P80 Oil Cooler Hose Replacement
Post by Sveedy »
A little side note regarding oil coolers -
I have had a few vehicles where the oil cooler ran through the radiator, like the early style Volvos. A mechanic told me that the design set-up was done to serve two purposes; cool the oil when hot, but also warm the oil up when cold. I guess kind of an equalizer of sorts.
1999 V70 GLT
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 337 times
Post by Chuck W »
Yeah.
You said you talked with do88. Their Heater Hoses for the RN P80s might be usable, but I don't remember the size of the hoses offhand. I want to say 5/8"/16mm.
Chuck W
Post by Chuck W »
Sveedy wrote: 31 Jan 2024, 09:47 A little side note regarding oil coolers -
The cooler (exchanger) on the pan does the same thing, just without the tedious hoses out front.
I did my pan swap as part of a manual swap and did away with ALL of those stupid hoses out at the radiator.
ericmci
Year and Model: 1999 S70 GLT
Has thanked: 73 times
Been thanked: 15 times
Post by ericmci »
Chuck W wrote: 31 Jan 2024, 09:48 Yeah.
Oh- you might be on to something there!
Looks like maybe some trimming but I think that could work.
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
Chuck W wrote: 31 Jan 2024, 05:09
The OP has an RN motored car. The oil cooler is on the pan, not in the radiator. This was one of the reasons I swapped pans on my '97.
Oops, I stumbled into '99 NoMansLand. I dimly recall Abscate talking about a chassis break on this very issue - compounded by the fact my '99 is NA-M.
jmartin919
Year and Model: S70 GLT SE 2000
Has thanked: 94 times
Been thanked: 39 times
Post by jmartin919 »
This uses a Gates 18821 hose on his P1
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
Sveedy
Post by Sveedy »
Chuck W wrote: 31 Jan 2024, 09:50
[/quote]
I see. That makes a bit more sense.
1999 V70 GLT
Chuck W
Post by Chuck W »
jmartin919 wrote: 31 Jan 2024, 10:53 This uses a Gates 18821 hose on his P1
That might work as a non-silicone substitute for the left hose on the cooler. The way it bends back out would be beneficial.
The P80 and P2 coolant pipes don't elbow out like the P1's evidently do, so saving some of that straightened leg would be good. I'd still personally rather have silicone hoses though.
ericmci
Post by ericmci »
DO88's latest response:
Hi Eric.
Thank you. Provided that the connection is indeed 14 mm, I suggest you buy one meter of this hose. Should be plenty enough to make a soft bend.
https://www.do88performance.com/en/arti ... -13mm.html
What do you think?
jmartin919
Seems like it would kink over time.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
