The reluctor ring on the driver side is all corroded and I have a brake warning and ABS code that are permanent.
Last year I struggled for a couple of weeks with heat and cans of every type of rust penetration fluid, trying to replace the passenger side ring but couldn't split the drive axle from the hub. I ended up taking the entire unit off the car, along with the cast aluminium knuckle, to a garage where they tried to press out the shaft with a hydraulic press.
The knuckle broke instead so I had to buy all replacement components.
I'm wondering if any one has ever tried or if you think it would work, to just remove the old ring with a chisel, clean the surface where it was and using new ring split in two (carefully sawn with a fine metal blade) then "glue" the two pieces of the ring where the old one used to be using something like loctite, or these new quick setting super glues..?
I will try it, one way or another, once the weather warms up but thought I would ask in ase anyone has ever had a go at something similar...
Could I use a "shortcut" to replace an ABS reluctor ring on a 2007 XC70?
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 123 times
- Been thanked: 115 times
I've replaced 3 by removing the old, cleaning, heating new one, and using the old one to smack the new one in with a hammer. Had no issues and never removed a driveshaft to do it.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- jonesg
- Year and Model: 2004 V70
- Has thanked: 69 times
- Been thanked: 479 times
i wouldn't do that, just do the job, you don't even know if its stuck yet.AylmerQc wrote: ↑05 Feb 2024, 19:07 The reluctor ring on the driver side is all corroded and I have a brake warning and ABS code that are permanent.
an air hammer might be a better choice over a press.
- 1283 Views
Last post by Skymongrel
- 279 Views
