1998 v70 stalling issue
surfbug1
Year and Model: 1998 V70, 2006 S80
Has thanked: 41 times
Been thanked: 9 times
Re: 1998 v70 stalling issue
Post by surfbug1 »
OK so I put an odb reader on this and got some codes
P0172 MAF sensor needs to be cleaned? Vac leak?
P0410 --- the air pump thing ....I guess I can hook up the diode to the circuit and fix. I thought I did this already, but maybe missed something. is there an easy plug in?
P0108 --- MAP sensor.....that's 70$ for aftermarket...will do this if still needed after (ECT and O2 sensors)
P0116---Engine coolant temp range fault
P0117---coolant ECT temp sensor fail.... put in an aftermarket sensor a few weeks ago, just now ordered a new Volvo factory sensor
temp out of range?
P0130 O2 sensor faults, ordered an upstream and downstream Bosch O2 sensors
P0300 misfires, general cylinder misfires
P0301 cyl 1 misfire (dunno why don't have P0303?)
P0302 cyl 2 mis
P0304 cyl 4 mis
P0305 cyl 5 misfire
Any added help or comments would be appreciated!
( I have O2 sensors, ECT and thermostat on order, will install on Saturday )
Got a C3 Corvette corvette for sale? 1968 to 1981...not the 1982 crossfire injection
Ping me!
:D
