Revisting AUX Input modification
machina
Year and Model: 2000 s70
Post by machina »
Hello All,
I have a 2000 S70 with 115k on it that I plan to drive for a while and want to get a better audio input working, that also uses Bluetooth. I know I could get a new head unit but my Volvo is in pretty great condition and I love the stock look.
I have read the many posts here and on other forums and had planned to do the tape deck mod paired with a Bluetooth adapter but was wondering if there is anything I have missed in terms of better solutions, especially since I have seen mentions that when the songs change on newer devices and there is silence this leads to a pop when the new song begins playing, potentially damaging speakers.
I have been looking into CD changer options as well, pricey but I want something reliable. Also can't find many threads on these so wanted to throw it out there. These are what I have found:
CD Changer Options:
https://www.discountcarstereo.com/a2d-v ... escription
https://gromaudio.com/store/aux1_adapte ... nAHox92ExA
BLUETOOTH version: https://gromaudio.com/store/bt3_adapter ... QNaG_nZNh8
https://www.aliexpress.us/item/32568052 ... ry_from%3A
Tape Deck Mod Write-Ups:
viewtopic.php?t=53690
http://www.atthetipwebs.com/technologyi ... eo_mod.htm
Thank you to everyone in advance for your help!! I hope this thread can be used by others as a more current resource for these mods, and a place where I can provide links to the tried and true best methods while standing on the shoulders of the giants who have developed this modification in the past.
Has thanked: 2215 times
Been thanked: 1853 times
If you want to spend a ridiculous amount of money, there are people on EBay selling Volvo SC-XXX radios modified for bluetooth. Somewhere in the $4-500 US range!
machina
Post by machina »
Yes, I have seen those, $4-500 seems a little crazy for a car of this age. However I am very curious about what method they are using, my current assumption is that they are using some type of FM modulator for the audio input, or some other soldered pins besides those on the cassette deck(which seems unlikely as would be surprised if someone on here would not have found them as well)
Has thanked: 1613 times
Been thanked: 4077 times
The FM Bluetooth converters work pretty well now, easy to pair, no noise. I’ll see if I can pull some brand names of onesi use that I like
FM converters are good if you can find a good brand. We had a cheap on and it died in about 3 months of limited use and took out the fuses in 2 different cars.
I appreciate you want to keep things stock, but I had a midrange Sony head unit fitted to my Toyota 4Runner with bluetooth and even a plug in for a back up camera. Not cheap but really worth it.
Yatour and Grom also do adapters for Sc-XXX head units. Crutchfield is a good resource for info, but they are pricy.
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
I made Bluetooth mod which uses ready library for Arduino fakes to be CD changer to get better AUX than via tape (it was personally tested awful when used phone which did not have physical contact to detect AUX) plus i included the forward, backward stop/play buttons on mine works over Bluetooth so can use buttons of radio control phone music player over Bluetooth.
Scroll little down and there is shortly all if you are in electronics.
https://xanthe.cc/?lang=fi&a=0a
jmartin919
Year and Model: S70 GLT SE 2000
Has thanked: 97 times
Been thanked: 42 times
Post by jmartin919 »
I'm cracking up reading your home page. When my translator converts to English it refers to transmission fluid as "vending machine blood"!
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
machina
Post by machina »
I agree with those saying FM adapter is a good solution, but with the unit I am using I still get buzz at high volume, I assumed it would have been better than a wireless one as well considering it plugs directly into the antenna port.
https://www.ebay.com/itm/361056538302?_ ... p_homepage
perhss70
Year and Model: s70 1997
Has thanked: 6 times
Been thanked: 3 times
Post by perhss70 »
I use an fm adapter too. I think it depends on the brand and where you live. I get a slight buzz sometimes but simply replugging the adapter seems to make it very minimal.for 10-15$ you can't go wrong
'97 S70 2.0T5
Caide
Year and Model: 2000 S70 T5
Post by Caide »
I wired a bluetooth receiver straight onto the tape inputs on the PCB, it has inputs for next/previous track which I had to cut traces on the front panel inputs to get working. The receiver has separate audio and data grounds so no buzzing/noise
