Hi all.
Does anyone know where I can get T5Lukes cem cracking software?
Vida CEM swapping
hampus10699
- Year and Model: 2006 V70
- xanthefin
- Year and Model: 1997 850
- Has thanked: 106 times
- Been thanked: 130 times
Sure i can tell more as i get finished with project i started last year. I have programming ready and all how i just need finish one last piece and make then it clean after mess as into one usable thing.Skavac wrote: ↑01 Mar 2024, 11:30Can you tell me more? You can program the remote if UEM is missing? Can the long UEM code be sniffed from radio?xanthefin wrote: ↑29 Feb 2024, 03:24 You need go another way if you want add used remote in UEM.
This way only good if you get UEM + remotes as you already noticed SEED Key is rolling one.
You need program they remote itself if want make it as a new specially when UEM is missing or sniff it all via radio.
ricked
- Year and Model: xc90
- Has thanked: 6 times
- Been thanked: 2 times
its gone...Dudde wrote: ↑01 Mar 2024, 14:16Page 223hampus10699 wrote: ↑01 Mar 2024, 14:11 Hi all.
here you can get it again:
30 days valid
https://easyupload.io/15802z
oscilloscope
- Year and Model: 2005
- Has thanked: 27 times
- Been thanked: 11 times
sounds interesting...xanthefin wrote: ↑01 Mar 2024, 14:19Sure i can tell more as i get finished with project i started last year. I have programming ready and all how i just need finish one last piece and make then it clean after mess as into one usable thing.Skavac wrote: ↑01 Mar 2024, 11:30Can you tell me more? You can program the remote if UEM is missing? Can the long UEM code be sniffed from radio?xanthefin wrote: ↑29 Feb 2024, 03:24 You need go another way if you want add used remote in UEM.
oscilloscope
i attempted to message the guy who is selling these legacy programmers in ru but i never received a reply. mind you it was quite some time ago i messaged. ( somthing like 2-3 years ago)Kravi80 wrote: ↑19 Feb 2024, 10:42http://www.ddmauto.ru/programmatoryi/st ... c-m30855fw
Clk, busy, p50, p60 no need to be connected in M32C UART mode (in M32C SPI must be connected).
Chips adm... and 93c86 must be desoldered.
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 603 times
You can read M32C for free with m16c-flasher.de software and $2 USB-UART adapter. Search for m16c-flasher.de in this topic for config and instructions.oscilloscope wrote: ↑03 Mar 2024, 13:48 i attempted to message the guy who is selling these legacy programmers in ru but i never received a reply. mind you it was quite some time ago i messaged. ( somthing like 2-3 years ago)
- sanjurjo
- Year and Model: 2003 V70R
- Has thanked: 3 times
Hi everybody,
I have a V70R MY2004 with a brick-style CEM (30657629).
What I want is to crack the PIN and upload it to d5t5 so I can enjoy VDASH even more.
What would be the right procedure here? As i understand, the only way to go with this CEM is to read it directly f.e. with an arduino nano using the code in this post (viewtopic.php?p=609357#p609357) from T5Luke. After that I would have the CEM-image as .bin. At what offset should I look for the PIN and how many bytes is it long? Or can T5Luke's tool (CEMtool) be used for finding it as well?
I'm completely new in this and I appreciate the work done here very much, as well as the patience with guys like me
vtl
At offset 0x4000 or 0x6000. CEM CPU is 16 bit big endian, on x86 you may need to swap the bytes to little endian, like:sanjurjo wrote: ↑06 Mar 2024, 09:12 Hi everybody,
00 11 22 33 44 55 -> 11 00 33 22 55 44
I don't now if T5Luke's software does it. When I desoldered the flash and read it in the programmer I had to swap bytes.
dikidera
- Year and Model: S60 2005
- Has thanked: 67 times
- Been thanked: 175 times
For byte swapping I recommend https://github.com/rgrahamh/byte-swappervtl wrote: ↑06 Mar 2024, 09:17At offset 0x4000 or 0x6000. CEM CPU is 16 bit big endian, on x86 you may need to swap the bytes to little endian, like:sanjurjo wrote: ↑06 Mar 2024, 09:12 Hi everybody,
Has prebuilt binaries for Windows and is great for this.
- 6431 Views
Last post by RickHaleParker
- 8699 Views
Last post by forumoto
