clutch pedal stays down
Clemens
Has thanked: 473 times
Been thanked: 219 times
Post by Clemens »
After an AT failure 2 years ago I M56 swapped my 96R with a pro mechanic friend's help last year. I used every part new and possibly OE. Everything worked fine till today my clutch pedal suddenly got stuck in the low position and won't return. This leads to a weird situation where the transmission is out of gear. I can move the shifter, but the gears don't engage. I would imagine that a shot clutch cylinder would not allow me to disengage the clutch, but not to engage the clutch. shouldn't the clutch self engage if the hydraulic fails?
Also: I bought eveything from Skandix. The slave cylinder is OE quality, the master is noname (didn't have Volvo or OE). I'd guess it is the master, but what would I use in the future if the one I have lasted less thanna year?
btw., there are no fluid leaks visible and the brake fluid reservoir is full.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1001 times
Post by volvolugnut »
Is there any travel evident at the slave cylinder? That is, is the actual clutch disengaged?
Clemens
Post by Clemens »
The clutch disengaged and got stuck. i can pull the pedal back out. if I press on the pedal, it goes down and stays there.
the weird thing is that the the clutch stays disengaged. with the motor running I can shift through the gears without getting any motion.
if the hydraulic fails I'd imagine it should engage. unless the throw out bearing or fork get stuck.
Summer: 1996 855 R
Donor: 1995 854 10V
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
Try bleeding the system first. Perhaps a clog has caused the fork to remain depressed.
96 M56
https://usparts.volvocars.com/p/Volvo_1 ... 81780.html
Has thanked: 1850 times
Been thanked: 1712 times
Release bearing has likely jammed. You need to get under the car and can you remove the rubber gaiter from the selector fork and have a look inside? You may be able to get a long screwdriver in there and persuade it back.
Otherwise as the guys have suggested one of the 2 hydraulic units has a failed seal not allowing the pressure to be released. I would suggest in that case it is the master cylinder.
Clemens
Post by Clemens »
I released fluid pressure at the slave and that didn't help. But tapping the slave with a hammer got it to release and the clutch did engage. Since the pedal still won't return but the clutch is in closed position I highly suspect the slave cylinder to be kaputt.
This is kinda good news because the throwout bearing would be way worse to replace.
Summer: 1996 855 R
Donor: 1995 854 10V
