P0305 code 96 850
2forty
Year and Model: 850 1996
Post by 2forty »
I have an error code p0305. What does the following scan readings mean.
Calc load 12
Ectf 204.8
Stftb1 0
Ltftb1 3.9
I know it is cylinder 5.
Installed new plugs.
Assistance Appreciated!
Has thanked: 2215 times
Been thanked: 1853 times
Check you are getting spark to the cylinder.
Check the spark plug boot is connecting the plug correctly.
Check the plug gaps are 0.028"
Check the distributor cap and rotor for damage and wear.
Check inside the distributor for leaking oil internally.
Last thing, check the cylinder compression. Low compression may mean a burnt valve.
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
2forty wrote: 12 Mar 2024, 19:59 I have an error code p0305. What does the following scan readings mean.
Calc load 12
Ectf 204.8
Stftb1 0
Ltftb1 3.9
P0305 Code Demystified — Cylinder 5 Misfire Detected
https://eeuroparts.com/blog/p0305-code- ... -detected/
My P0304 turned out to be the #4 injector. I started with the plugs and coils then fuel. Hindsight it's the easiest to check the injectors first.
viewtopic.php?p=642607#p642607
2forty
Post by 2forty »
Thanks for all of the replies!
